SP1 pro Autodesk Simulation CFD 2014
Název fóra: Simulation, CFD, CAE
Popis fóra: Otázky k CAE aplikacím pro simulace a analýzy, Autodesk Simulation, CFD, Moldflow, Sim Studio, Simulation Composite, Robot Structural Analysis, Flow Design
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=17557
Datum vytištění: 10.říj.2026 v 08:36
Téma: SP1 pro Autodesk Simulation CFD 2014
Předmět: SP1 pro Autodesk Simulation CFD 2014
Datum odeslání: 22.čvc.2013 v 22:54
Byl uvolněn Service Pack 1 pro simulační CAE aplikaci http://www.cadstudio.cz/prod/simulation-cfd.asp - Autodesk Simulation CFD 2014 . Ke stažení viz Download.
Přehled oprav v SP1:
Issues Addressed in this Service Pack
*         After opening an Inventor part or assembly directly into Simulation CFD, using the Add/Update Design command results in an error.
*         In certain situations, mouse navigation (pan, zoom, and rotate) has delays and is slow to respond.
*         Revit 2014 models in metric units are scaled by a factor of 1000 when launched into Simulation CFD 2014.
*         An error with the Material Dictionary file occurs when running SimCFDConfig to change the user interface language. The error was also seen when installing on a non-English system in a non-default path.
*         The solver hangs when saving intermediate results for conduction-only (no flow) simulations with temperature boundary conditions and intermediate results output.
*         Importing a large Free Surface Component Acceleration table caused a crash.
*         The function that maps CFD results to FEA loads fails on 32 Bit platforms.
*         In certain situations, the "Share file" was corrupted due to issues with part names. Note that this bug fix affects future simulations, and cannot correct issues in simulations created in previous builds.
*         A two-dimensional axisymmetric simulation fails when using the new distributed resistance formulation in Simulation CFD 2014.
*         An error message about failing to create the Attribute Set was issued when launching a specific model from Inventor into Simulation CFD. The problem was traced to a specific feature in the model.
