Byl uveden Service Pack 2 pro AutoCAD Civil 3D 2013. Obsahuje i opravy ze SP1 pro Civil, ze SP2 pro AutoCAD a ze SP2.1 pro Map. Ke stažení jej najdete na stránce Download. Pozor, tentokrát SP2 nepřináší oficiální kompatibilitu s Win8 - v SP2 byly upraveny některé funkce, aby fungovaly pod Win8, ale na rozdíl od ostatních SP2 pro řadu AutoCAD 2013 nepřináší tento Service Pack oficiální Win8-kompatibilitu. Tu nabízí až Civil 3D 2014. Přehled oprav v SP2: The following issues have been resolved in AutoCAD Civil 3D 2013 Service Pack 2: .NET API - Setting the Description property in a PointGroup object no longer causes an error.
- An unexpected error no longer occurs when calling ExportAsPolyline3d on a CorridorFeatureLine containing a break point.
Alignments - Closing the Superelevation Curve Manager no longer causes the application to close unexpectedly.
- An issue that affected the visibility of feature lines in certain regions has been resolved.
Corridor Design - Handling of large station values has been improved.
- Closing a drawing while the Corridor Section Editor is open no longer causes the application to close unexpectedly.
- Importing a duplicate subassembly no longer causes errors after prompting to overwrite the existing subassembly.
- Adding a subassembly to a LinktoMark point in an offset assembly no longer causes an error.
Cross Section Views - Volume tables now remain as saved when reopening the drawing.
- Changing Section View Group Bands now adds labels automatically when you modify or add values in the Section View Group Properties dialog box.
- Changing the material style of a section in the Object Properties Manager no longer causes the application to close unexpectedly.
Feature Lines - An unexpected error no longer occurs when grip-editing a feature line after undoing the FILLETFEATURE command.
General/Other - When closing AutoCAD Civil 3D 2012 on a system with AutoCAD Civil 3D 2013 installed side-by-side, a blank warning dialog is no longer generated.
- Stability when installed on a Windows 8 operating system has been improved.
Hydraflow Storm Sewers - The pipe shape settings for box and elliptical pipes are now respected upon import.
Hydraflow Express - The accuracy of the Modified Rational SDF value has been improved.
Hydraflow Hydrographs - The accuracy of the Modified Rational SDF value has been improved.
Labels - Latitude and Longitude are now displayed as expected in General Note Labels.
- Profile station labels using station index format with rounding are now displayed correctly.
- Alignment labels using the crows foot block are now aligned as expected.
Lines/Curves - The Create Curves Between Two Lines and the Create Curves On Two Lines commands now work as expected.
Object Enabler - An error when displaying surface contours in a RealDwg environment has been resolved.
Parcels - Copy and pasting a parcel table with a LineBetweenTwoPoints label no longer causes the application to close unexpectedly.
Pipe Networks - An error when displaying Pipe Network Vistas has been resolved.
- An error when deleting a pipe or structure with Prospector hidden has been resolved.
- The accuracy of the Part Builder Data Structure Table has been improved.
- The structure style block rotation is now aligned with the 3D solid.
Plans Production - Masked match lines now retain the expected appearance when editing the position of a view frame.
- When creating a new sheet using plan production tools the north arrow is now oriented as expected.
Plotting - An issue that caused a "command in progress" error when plotting a window has been resolved.
Point Clouds - LIDAR Point Classification style settings are now displayed as expected.
- An issue that caused inaccurate loading of an ESRI ASC file has been resolved.
Pressure Networks - An issue that prevented a part from the pressure pipe catalog to be inserted into the drawing successfully has been resolved.
- Valves in profile view are now scaled as expected in metric drawings.
- An issue that caused an error when running the FollowSurfaceINPV command has been resolved.
Profiles - Importing profile view band label styles now overwrites an existing band style as expected.
- An issue that caused pipes or profiles to display incorrectly when switching layouts or plotting has been resolved.
- An issue that caused the grid in a profile view to be displayed incorrectly has been resolved.
Project Management - Used and where used information is retained when re-checking in a drawing into Vault.
- DwgRelPath retains leading periods on Windows XP based workstations.
Projection - 3D solids projected in section view are now displayed as expected.
Prospector - Parcel information is now displayed as expected after sorting in list view.
Quantity Takeoff - After changing a material, the name and style are now listed correctly in on the Sections tab of the Sample Line Group Properties dialog box.
- Creating a materials list from a sample line group no longer causes the application to close unexpectedly.
Subassembly Composer - Importing a subassembly with a long path name no longer causes the application to close unexpectedly.
Shortcuts - An issue that caused pipes and pipe labels to not plot as expected has been resolved.
- Creating a reference to a grid surface no longer causes the application to close unexpectedly.
- An issue that caused profile labels to not display as expected has been resolved.
Surface - New surfaces created from a DEM now use the user specified coordinate system.
- Waterdrop polylines now display proper linetype generation.
Survey - The accuracy of the traverse analysis report has been improved.
- The latitudes and departures for the face 2 observations are now calculated as expected.
- An issue that caused incorrect display of Northing and Easting values without updating the network has been resolved.
- The performance of importing a fieldbook has been improved.
- The performance of updating a network has been improved.
- The performance of the Least Squares Analysis command has been improved.
- Accuracy when using a reciprocal observation field book file has been improved.
- Inserting a traverse into the drawing no longer results in rotated linework.
