Jako poslední ze série Service Packů 2 pro rodinu AutoCAD 2013 byl uveden SP2 pro AutoCAD Plant 3D 2013. Kromě oprav ze SP2 pro AutoCAD 2013 nabízí: P&ID Drawings
- The exporttoautocad command breaks acquisition rules.
Data Properties
- Plant data in project drawings occasionally does not save
properly. Data loss can occur when working with custom classes, if a drawing is
removed and added again, or when modifying referenced (XREF) drawings.
Fixes that apply to AutoCAD Plant 3D only:
3D Model
- Modifying staircase step data occasionally causes the program
to shut down unexpectedly.
- If a block that contains piping is inserted into a non-project
drawing, a recovery error message displays when the non-project drawing is
opened.
- Exported SDNF files do not reflect recent edits.
Isometric Drawings
- Coordinates added to end connections (CONT'D ON) do not
display in the isometric drawing.
Spec Editor
- The Spec editor requires Admin rights to modify a piping spec
or catalog.
Note: With this hotfix applied, you are not
required to have admin rights to modify a piping spec or catalog. However, other
Spec Editor features do require that you run the Spec Editor with admin rights
(using Run as administrator). For example, admin rights are required to modify
the shared content folder or to edit description styles.
SP2 je ke stažení na stránce Download. Viz též přehled SP v tipu http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2013-tip8770 - http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2013-tip8770 a opravy pro Plant 3D na http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD+Plant+3D - http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD+Plant+3D
