Byl uveden první service pack pro Electrical 2014 (samostatné verze i verze v Design Suites). Krátce byl k dispozici i nesprávný SP1, proto má tento SP označení 1.1. Ke stažení viz: http://www.cadstudio.cz/download?ccat=5&file=2014 - http://www.cadstudio.cz/download?ccat=5&file=2014 Viz též: http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2014-tip9452 - http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2014-tip9452 http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD+Electrical - http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD+Electrical Přehled oprav v SP1.1: Cross Reference - Symbol mapping option of the table style cross referencing does not work unless the library is listed first in the Project Properties.
Catalog Lookup - Catalog data shifts some of the columns when do the Catalog Lookup for some special database.
- Catalog lookup locks up when switch from a table have more columns to a table have less columns.
Insert/Edit Components/Footprints - Insert Panel from Schematic list may fail in some Localization version.
- DESC1, DESC2 and DESC3 are not copied to multi-pole when insert child poles.
Ladder - Set Line reference values with sheet number template does not update to match the drawing sheet number during creation of new drawing.
Project Tools - Project_wide update always save drawings in 2013 format.
- Component Update From Catalog does not work well to update the Weblink and Pinlist.
Tagging - Fails to recognize duplication of tag when working with multiple drawings.
Terminal Strip Editor - Cannot sort by all column headers in Terminal Strip Editor.
