Byl uveden Service Pack pro AutoCAD Architecture 2014 (samostatné verze i verze v Design Suites) a AutoCAD MEP 2014. Ke stažení viz: http://www.cadstudio.cz/download?ccat=8&file=2014 - http://www.cadstudio.cz/download?ccat=8&file=2014 Viz též: http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2014-tip9452 - - http://www.cadforum.cz/cadforum/prehled-doplnkovych- - patchu-pro-rodinu- - autocadu-2014-tip9452 http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD+Architecture - http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD+Architecture Přehled oprav v SP1: Project Navigator - Closing AutoCAD Architecture while the Project Navigator is open may cause occasional crashes.
Object Viewer - Crash when saving an image in the object viewer while the steering wheel is enabled.
Schedule Table - Modifying text height appearance in schedule tables results to a crash.
Boolean Operation - Some objects may disappear after performing Boolean operations such as cleaning up, inserting a window, modifying a roof line, and so on.
Corner Window - Elevations or sections of corner window styles may display incorrectly.
Elevation Label - Elevation labels may not reflect the current elevation location. As a work around, use AecElevationLabelClearCache command to fix the elevation labels with incorrect elevation location values.
Object Viewer - Some visual styles do not work in the object viewer.
Section - Generated sections may not display all lines.
WebDAV - Failure to create projects on WebDAV servers.
