Update 3 pro Inventor 2014 Service Pack 1
Název fóra: Inventor
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=18931
Datum vytištění: 12.říj.2026 v 09:36
Téma: Update 3 pro Inventor 2014 Service Pack 1
Předmět: Update 3 pro Inventor 2014 Service Pack 1
Datum odeslání: 13.bře.2014 v 07:31
Dnes byl uveden nový update pro Inventor 2014 se SP1. Update 3 je kumulativní - obsahuje i opravy z předchozích dvou updatů. Řada oprav se týká grafiky. Update 3 si můžete stáhnout http://knowledge.autodesk.com/sites/default/files/file_downloads/INV18130.zip" rel="nofollow - zde  (41MB).
Přehled oprav:
  • Graphic Issue with Display True line weight
  • The edges will disappear when zooming the model with section view under shaded with edges visual style
  • Abnormal triangles appear occasionally for some large assemblies and drawings
  • Some portion of the assembly disappear during zoom
  • Shading in drawing view disappears when zooming
  • Graphics not rendering correctly, leaving ghosted and/or missing parts in assemblies
  • Poor decal quality in Performance Mode
  • Unexpected exit with error message "Display driver stopped responding and has recovered"
  • Unexpected exit when opening IDW
  • IDW Property text is moved when saved as AutoCAD DWG
  • Unable to offset in 2d sketch
  • Unexpected exit during move item with Tube&Pipe items attached due to Bolted Connection
  • Unexpected exit due to WPF application rendering in Hardware Acceleration mode
  • Transparent components disappear from graphic when zoom in/out after create or delete constrains
  • Unexpected exit when zoom in or rotate the freeform body
  • Editing iPart table via Excel 2013 will not save if another Excel documents open
  • Inventor locks up or unexpectedly exits when view degrees of freedom of an assembly that has patterned components
  • Color assignments lost when saving as STEP AP214
