Update 1 pro Inventor 2015
Název fóra: Inventor
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=19403
Datum vytištění: 01.lis.2026 v 15:02
Téma: Update 1 pro Inventor 2015
Předmět: Update 1 pro Inventor 2015
Datum odeslání: 03.čer.2014 v 15:29
Byl uvolněn "Update 1" pro Inventor 2015 (všechny verze, včetně Suites). Ke stažení na stránce Download. Opravuje následující problémy:
  • 1511-131: Workplane display prevents view at half section of assembly
  • 1356-879: ACAD DWG with 3D entities with units in meters will be imported into Inventor in millimeters
  • 1516-744: After shrinkwrap composite surface disappear and editing of derived assembly cause change of the composit to solid
  • 1515-420: Cut normal fails on a contour flange with two adjacent bends
  • 1515-741: Failure to create tangent constrain for Interpolation Spline
  • 1517-216: FreeForm edit change not recognized as a model change
  • 1503-797: Inventor HSM doesn't support Redo cases
  • 1517-320: OpenSSL Heartbleed security vulnerability
  • 1517-033: Section view of assembly containing Content Center parts gives incorrect result
  • 1512-957: Unable to constrain when changing the dimension
  • 1368-705: When the background color is changed, it becomes difficult to see the dimension text
  • 1510-315: Unexpected exit during move item with Tube and Pipe items attached due to Bolted Connection
  • 1517-158: Unexpected exit during sketch contraint
  • 1517-042: Unexpected exit if calling FindUsingVector API in OnPreSelect event handler if in Assembly file
  • 1515-915: Unexpected exit when opening certain files with stored VBA code or when attempting to open the VBA editor within Inventor
  • 1515-841: Unexpected exit on Cut Normal on a sheet metal part with contour flange and contour roll
  • 1516-155: Unexpected exit saving drawing standard with imported materials in hatch pattern defaults
  • 1516-460: Unexpected exit when attach the incorrect point cloud model
  • 1515-447: Unexpected exit when attempting to edit a sick sweep
  • 1515-205: Unexpected exit when copy and paste Workplane
  • 1510-709: Unexpected exit when editing hole
  • 1516-366: Unexpected exit when enter Frame Analysis environment after Insert Frame
  • 1515-464: Unexpected exit when import the style (with matrial changed) which was previously exported
  • 1515-747: Unexpected exit when open a drawing
  • 1505-565: Unexpected exit when retrieving dimension
  • 1515-073: Unexpected exit when saving as dwg file
  • 1515-879: Unexpected exit when the user switches to LOD with missing reference file on forward creating derive assembly
  • 1516-447: Unexpected exit after undo and delete moved component
  • Multiple general stability enhancements
