Uveden Service Pack 1 pro AutoCAD 2015
Název fóra: AutoCAD
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=19443
Datum vytištění: 03.lis.2026 v 06:35
Téma: Uveden Service Pack 1 pro AutoCAD 2015
Předmět: Uveden Service Pack 1 pro AutoCAD 2015
Datum odeslání: 10.čer.2014 v 10:08
Byl uveden SP1 pro AutoCAD 2015 a AutoCAD LT 2015 (všechny jazyky, včetně verzí Suites). Kromě oprav zahrnuje i novou proměnnou [VAR]CURSORBADGE[/VAR]. SP1 jsou ke stažení v sekci Download.
Viz též:
http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD - http://www.cadforum.cz/cadforum/produkty.asp?prod=AutoCAD
http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2015-tip9815 - http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2015-tip9815
Přehled oprav:
As a result of the detailed information that we received from customers who used the Customer Error Reporting Utility, several problems were identified and fixed. Updates have been made in the following commands and features:
DB Connect
  • Occasional crashes when using DB Connect feature on 64-bit machines with 4GB and more RAM.
Status Bar
  • Occasional crashes when opening drawing file when a bubble notification is still displayed.
New Tab
  • Occasional crashes when clicking New in the Quick Access Toolbar or the Start Drawing tile on the New Tab page.
  • Occasional crashes when clicking the New Tab Plus button after adding LayerFilterComboControl or Filter in the CUI dialog box.
Design Center
  • Occasional crashes when inserting a block from Design Center on the second time.
General
  • Occasional crashes when selecting the "Fully open the drawing file" option that displays when opening a drawing that was saved in the partial open state.
  • Occasional crashes when exiting AutoCAD.
The following defects have been fixed:
3D Modeling
  • Using the ViewCube dropdown for selecting a saved UCS will not accept UCS names that contain a space.
  • The SCALE command is not applied correctly for scale factors less than 1/100th.
Display
  • Cursor trails will display on the screen for users with Optimus or Dynamic Switchable Graphics technology.
Hatch
  • Lineweight is applied and displayed for solid hatch objects.
  • Additional lines display in the selection highlighting for a solid hatch object.
  • Hatch objects do not apply LAYLOCKFADECTL or XDWGFADECTL.
  • The angle of a gradient changes the appearance of that gradient.
  • Solid hatch objects display the edge color.
Plot
  • ViewCube will appear on plots under certain conditions.
VBA
  • Unable to execute SendCommand API in multiple drawings.
General
  • The number of recently used files accepts a maximum of 10. The maximum has been restored to 50.
Security Hotfix
