SP2 pro Map a Civil 3D 2014
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=19607
Datum vytištění: 04.říj.2026 v 05:39
Téma: SP2 pro Map a Civil 3D 2014
Předmět: SP2 pro Map a Civil 3D 2014
Datum odeslání: 15.čvc.2014 v 17:47
Byl uveden Service Pack 2 pro AutoCAD Map 3D 2014 a z něj vycházející Service Pack 2 pro AutoCAD Civil 3D 2014. Přehled oprav a stažení instalace - viz Download a přehled patchů.
Corridor Modeling and Analysis
  • An issue has been resolved where corridor materials were not being calculated for both sides of a roadway and in cases where there were corridors with multiple, non-parallel baselines.
  • An issue has been resolved with the SampleLineGroup.Create() API method.
  • An issue has been resolved where corridor solids were not exported to original coordinates.
  • An issue has been resolved where corridor solids were not exported properly for corridor links.
  • An issue has been resolved where corridor solids were not exported properly for specific areas of intersections.
Pipe Networks and Pressure Networks
  • An issue has been resolved where alignments were not created properly from a pressure network that had branches.
  • An issue has been resolved where parts from a custom part list were resizing to the smallest part in the part family when subsequent parts were added.
  • An issue has been resolved where data-referenced gravity pipe network styles were reset when the source model was updated and the network was synchronized
  • An issue has been resolved where pressure networks were not created properly when using the Create Pressure Network from Industry Model command.
  • An issue has been resolved where the height of the first structure in a gravity pipe network was not set properly when using a 3D polyline as the selected object.
  • An issue has been resolved where gravity pipe and structure collections could not be selected in the Prospector tree.
Alignments and Profiles
  • A data-specific issue has been resolved where profiles were shifting when an AutoCAD Civil 3D 2012 drawing that contains profiles was opened in AutoCAD Civil 3D 2014, which resulted in a change in stationing.
  • An issue has been resolved where the cursor appeared to be offset from its actual location when laying out and editing a profile.
  • An issue has been resolved where the geometry curve lengths for rail alignments could not be edited in the tabular editor.
Miscellaneous
  • An issue has been resolved where turning off the navigation bar and ViewCube would result in lineweights not being applied properly during plotting for certain AutoCAD Civil 3D objects.
  • An issue has been resolved where unexpected characters and text was added to objects in a drawing and within any drawings that were opened during the AutoCAD Civil 3D session.
  • A performance issue when logging into Autodesk® Vault from AutoCAD Civil 3D 2014 has been resolved.
  • An issue has been resolved where the Transformation Grid Scale Factor was not applied properly for ground coordinates when using the Geodetic Calculator.
  • An issue has been resolved where the Print button in the Hydraflow Express Rainfall IDF Curve dialog box would not work properly.
  • An issue has been resolved where pay item formulas were not properly incorporated into take off.
  • An issue has been resolved where special characters in an AutoCAD Civil 3D object name would cause an issue when an IMX file that contained these characters was imported into Autodesk® Infraworks™.
  • An issue has been resolved where the north arrow was not being rotated properly when using the Plan Production tools.
