Byl uveden SP1 pro AutoCAD Civil 3D 2015, poslední z řady service packů 1 pro rodinu AutoCADu 2015. Můžete si jej stáhnout ze stránky Download. Civil SP1 obsahuje i opravy ze SP1 pro AutoCAD a pro Map. Viz též: http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2015-tip9815 - http://www.cadforum.cz/cadforum/prehled-doplnkovych-patchu-pro-rodinu-autocadu-2015-tip9815 http://www.cadforum.cz/cadforum/produkty.asp?prod=&ver=2015&q - http://www.cadforum.cz/cadforum/produkty.asp?prod=&ver=2015&q = Přehled oprav civilovských funkcí: The following issues have been resolved in Autodesk AutoCAD Civil 3D 2015
Service Pack 1:
Corridor Modeling and Analysis
- A data-specific issue has been resolved where attempting to rebuild a
corridor would cause the application to close unexpectedly.
- An issue has been resolved where material take off would compute only half
of the areas of the materials when more than one baseline existed.
- An issue has been resolved where the corridor feature line areas were not
using the code set styles assigned to the corridor.
- An issue has been resolved where the elevation target in the DaylightBasin
and DaylightBasin 2 subassemblies was incorrectly solving for the basin
elevation.
- An issue has been resolved where the German Country Kit assembly
GermanSA_Fahrbahn_ausserorts was missing the feature line on the right side in a
cut terrain situation.
Pipe Networks and Pressure Networks
- An issue has been resolved where data-referenced gravity pipe network styles
were reset when the source model was updated and the network was synchronized.
- An issue has been resolved where data-referenced pressure network styles
- An issue has been resolved where pressure networks were not created properly
when using the Create Pressure Network from Industry Model command.
- An issue has been resolved where an invalid part and/or pipe style within a
pipe network would cause the application to close unexpectedly.
Alignments and Profiles
- An issue has been resolved where editing an alignment when another profile
had been superimposed onto its profile would cause the application to close
unexpectedly.
- An issue has been resolved regarding the adjustment of the profile station
range when creating a profile after creating and deleting an unrelated
alignment.
Survey
- A utility which provides the ability to save an AutoCAD Civil 3D 2015 survey
database for use in AutoCAD Civil 3D 2014 is included in this service pack. This
utility can be accessed from the AutoCAD Civil 3D Toolbox after installing this
service pack.
- An issue has been resolved where attempting to delete a survey figure from
the Figures Editor would cause the application to close unexpectedly.
Grading and Surfaces
- An issue has been resolved where deleting all grading projections and
repeatedly running the UNDO command would cause the application to close
unexpectedly.
- An issue has been resolved where deleting points from a surface when the
DACH Extension is installed would cause the application to close unexpectedly.
- An issue has been resolved where draped images that were rendered when
hardware acceleration was turned on would be mirrored.
Miscellaneous
- An issue has been resolved where a description was not included from a
data-referenced source object.
- An issue has been resolved where unexpected characters and text was added to
objects in a drawing and within any drawings that were opened during the AutoCAD
Civil 3D session.
- An issue has been resolved where starting AutoCAD Civil 3D in zero document
state startup mode would cause the application to close unexpectedly.
- An issue has been resolved where the correct CODES file was not being read
from the registry.
- An issue has been resolved where modifying an object on a locked layer would
- An issue has been resolved where a curve label would show its content
reversed when located at 0 and 180 degrees in a drawing.
- An issue has been resolved where the Print button in the Hydraflow Express
Rainfall IDF Curve dialog box would not work properly.
