Autodesk uvedl dvě nové aktualizace pro rodinu produktů Revit - "Service Pack 1 pro Revit 2016" a "Update Release 8 pro Revit 2015 R2". Aktualizace vám nabídne komponenta Application Manager nebo si je můžete stáhnout zde ze stránky Download. Přehled oprav v SP1 pro Revit 2016 (položky označené * byly nahlášeny uživateli Revitu): Platform
- eTransmit
- Corrects an eTransmit issue with handling dependent views placed on
sheets when the parent view is not placed on a sheet and the user specifies to
only include views on sheets.*
- Family
- Corrects an issue that caused undesired behavior in some projects when
loading a family.
- Corrects an issue that caused a failure for constraints to a nested
instance when elements in a family were grouped.*
- Improves stability when selecting to delete corrupted families during
upgrade from Revit 2015.*
- Graphics
- Improves stability when rendering with Autodesk Raytracer.*
- Corrects an issue when rendering with graphic overrides.
- IFC
- Improves creation of Revit objects from imported faceted
geometry.
- Linked RVT Files
- Improves visabilty where the RVT link is unloaded but remains visible
in the view until another redraw occurs.
- Point Clouds
- Improves stability while reloading the point cloud file if the point
cloud file root path was changed in the Options dialog.*
- Upgrade
- Improves stability when canceling a File Open/Upgrade operation from
an empty Revit window.*
- View
- Corrects a display error that occurred when the Review Warning dialog
was open.
Architecture
- Wall
- Corrects wall layer display issue in vertically compound wall with
adjacent edges after mirror operation.
MEP
- Annotation
- Corrects an issue that could cause tags to move when using Trim/Extend
to join elements.*
- Color Fill
- Corrects an issue where ducts and pipes displayed with centerlines
only, and duct and pipe fittings displayed colored, if the Duct/Pipe Color Fill
category was turned off in Annotation Categories in Visibilty/Graphics
Overrides.
- Fabrication
- Improves interoperability behavior so fabrication parts will now adopt
the material, specification, and insulation parameters from the part you are
connecting to.
- Improves the highlighting of the selected controls in the MEP
Fabrication Parts palette.
- Corrects an issue that could cause an invalid connection to be
maintained after changing the Specification setting of a fabrication
part.
- Improves stability when opening a fabrication job in Revit.*
- Corrects an issue that could cause fabrication parts to use incorrect
dimensions after being edited through the Edit Part dialog.
- Corrects an issue that would allow a tap to be modified to a size that
is incompatible with the main.
- Corrects an issue that could cause instability in Revit when all
fabrication services are loaded into the project.
- Corrects an issue that could cause inappropriate behavior when placing
a fabrication tee that uses a calculated length.
- Connectors
- Improves stability when modeling from connectors in MEP
families.*
- Duct
- Corrects an issue that could cause dimensions to reverse on sloped
duct fittings when using the Trim command.*
- Corrects an issue that could cause incorrect modification of a duct
branch without issuing a disconnect warning.*
- Duct/Pipe Display
- Corrects an issue that could cause incorrect behavior when adding a
vertical pipe from an upgraded tee.
- Mechanical
Systems
- Corrects an issue that prohibited the use of the Check Systems tools
when a view template has been applied.*
- Pipe
- Corrects an issue that caused an error when connecting to an element
in a group.*
- Corrects an issue that could prohibit changing the type of a fitting
or accessory.*
Structure
- Analytical Model
- Corrects an issue with the analytical floor horizontal alignment for a
sloped floor.*
API
- Corrects an issue with DimensionSegment.TextPostion API when handling
a dimension with more than one segment.*
- Corrects an issue to make sure that third-party developers always have
the correct value when using the public API to get the upper value or lower
value of the conditions.
- Corrects an issue that occurred when copying or mirroring an
electrical circuit so that wire types are correctly copied as part of the
electrical system.*
Přehled oprav v UR8 pro Revit 2015:
Autodesk Revit Platform 2015 Updates
Improves Stability while reloading point cloud file if the point cloud file root path was changed in the Options dialog.*
Improves stability when placing spot elevations.*
Improves stability when moving a spot elevation and zooming in and out of a view.*
Improves stability when exporting schedules.*
Improves stability when exporting views to DWG.*
Autodesk Revit MEP 2015 Updates
Fixes an issue that could cause lighting fixtures in copies of a group to disappear when the group is modified.*
Improves stability when modeling from connectors in MEP families.*
Autodesk Revit Structure 2015 Updates
Corrects an issue with the analytical floor horizontal alignment for a sloped floor.*
------------- Vladimír Michl (moderátor) https://www.linkedin.com/in/vmichl/ - LinkedIn , Autodesk Expert Elite
