Byl uveden Service Pack 3 (SP3) pro AutoCAD Civil 3D 2015. Obsahuje i opravy ze SP1 a SP2 (a opravy AutoCADu). Ke stažení na stránce Download. Přehled nových oprav v SP3: Export Civil 3D Drawing
- An issue has been resolved where the application to close unexpectedly
during conversion
- An issue has been resolved where the resulting profile curve tessellation
was lower than it was in the original version of AutoCAD Civil 3D 2015.
- An issue has been resolved where the AutoCAD Color Book could not be
remapped to AutoCAD Color RGB.
- An issue has been resolved where the Replace ByLayer Properties with Layer
properties did not work.
- An issue has been resolved where the default Seed file path was empty in the
Export Settings dialog box.
- An issue has been resolved where on a profile with a crest curve, the
resulting alignment polyline was broken at the curve.
- An issue has been resolved where elements were exploded to the wrong layers.
- An issue has been resolved where COGO Point objects were exploded to
graphics and not blocks.
- An issue has been resolved where using certain CSV mapping files caused SS2
export to fail.
- An issue has been resolved where surface contours were exploded to Lines
instead of polylines.
- An issue has been resolved where after converting a Civil 3D drawing to DWG,
surface contour labels masks were missing.
Grading and Surfaces
- An issue has been resolved where moving a grading caused the applcation to
close unexpectedly.
- An issue has been resolved where rotating a surface caused the application
to close unexpectedly.
- An issue has been resolved where in the Surface style, a layer could not be
set for some style components.
- An issue has been resolved where in Layout mode, contours did not display as
expected.
Water Analysis
- An issue has been resolved where opening certain projects in Hydraflow Storm
Sewer caused the application to close unexpectedly.
- An issue has been resolved where importing an STM file updated all pipes to
the same size and material.
- An issue has been resolved where Inlet and Gutter Spread values were shown
as same the value regardless of the actual condition.
Vault and Data Shortcuts
- An issue has been resolved where setting the data shortcut working folder
and then opening a drawing would cause the application to close unexpectedly.
- An issue has been resolved where importing a zip file or a project folder
would cause the application to become unresponsive.
- An issue has been resolved where importing a local project folder or zip
into Vault casued data shortcuts to disappear.
- An issue has been resolved where opening Civil 3D drawings via Vault within
Civil 3D took a long time.
- An issue has been resolved where when importing a project with published
objects, the published objects were not listed in Prospector.
- An issue has been resolved where when a project under a folder to a zip file
was exported, re-importing it would fail.
- An issue has been resolved where duplicate profiles disappeared after
importing their host folder into Vault.
- An issue has been resolved where when there were a large number of projects,
it took a long time to display the "Select Projects to Display" dialog box.
Pipe Networks and QTO
- An issue has been resolved where on curved pipes, using a linetype with text
caused text to be mirrored.
- An issue has been resolved where limiting the extents of a takeoff to a
range of alignment stations calculateed incorrectly if the range contained more
than one region.
Miscellaneous
- An issue has been resolved where the Command Line would freeze when
switching drawings in the Windows task bar while the Level of Detail mode was
active.
