UR9 pro Revit 2015
Název fóra: Revit, BIM
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=21395
Datum vytištění: 21.zář.2026 v 23:46
Téma: UR9 pro Revit 2015
Předmět: UR9 pro Revit 2015
Datum odeslání: 25.čvc.2015 v 16:36
Byla uvedena devátá "Update Release" pro Revit 2015. Je určena pro běžný Revit 2015 i verzi R2 (subscription). Ke stažení na stránce Download nebo přes Application Manager.
Opravuje tyto problémy nahlášené uživateli:
Autodesk Revit Platform 2015 Updates
    Improves stability when deleting an element which contained an invalid partition ID.*
 Improves visual fidelity when exporting to DWF.*
 Improves data consistency between a schedule view and a schedule instance on a sheet.*
 Improves stability while upgrading Revit 2012 projects.*
 Improves stability while editing families.*
 Improves stability when using the Options dialog to log into A360 from a workshared central file.*
Revit MEP 2015 Updates
    Improves stability when upgrading a project that contains user-created pipe types.*
Revit Structure 2015 Updates
    Improves stability while when placing a slanted column or a beam based on a Generic Model Line based family.*
 Improves stability when reloading an annotation symbol family used as a symbolic representation of brace elements on plan views.*
Revit API 2015 Updates
    Improves stability while when editing families which use external resources for keynotes.*
