SP1 pro AutoCAD Civil 3D 2016
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=21427
Datum vytištění: 03.říj.2026 v 13:11
Téma: SP1 pro AutoCAD Civil 3D 2016
Předmět: SP1 pro AutoCAD Civil 3D 2016
Datum odeslání: 03.srp.2015 v 17:30
Byl uveden Service Pack 1 pro AutoCAD Civil 3D 2016. V průběhu následujících dnů se objeví i ve vašem Application Manageru. Můžete si jej ale stáhnout už teď, v sekci Download.
Přehled oprav a rozšíření:
Enhancements Included in This Service Pack
The following enhancements have been made in Autodesk AutoCAD Civil 3D 2016 Service Pack 1:
  • A .NET API is now available for feature lines.
  • DGN 3D Polyline linetype are now supported.
  • Hydraflow Storm Sewers now exposes K inflow coefficient values in calculation results.
  • Hydraflow Storm Sewers now supports the Composite Energy Loss Method (FHWA HEC-22 2001), which requires both critical depth as a minimum depth and that the inlet control checks be selected. This supplements the Automatic condition which used only the geometry of the network to determine the energy losses at junctions.
The following issues have been resolved in Autodesk AutoCAD Civil 3D 2016 Service Pack 1:
Alignments, Corridors, and Quantity Takeoff
DWG and DGN Export
Gravity and Pressure Networks
Import and Attach Coordination Model
Linetypes
Open InfraWorks 360 Model
Plotting and Annotation
Surfaces and Feature Lines
Vault and Data Shortcuts
