Uveden SP2 pro AutoCAD Map 3D 2016
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=22171
Datum vytištění: 07.říj.2026 v 06:50
Téma: Uveden SP2 pro AutoCAD Map 3D 2016
Předmět: Uveden SP2 pro AutoCAD Map 3D 2016
Datum odeslání: 25.led.2016 v 19:17
Byl uveden druhý Service Pack pro AutoCAD Map 3D 2016 a Infrastructure Administrator 2016 (obsahuje i SP1). Ke stažení viz sekce Download.
Přehled oprav v Autodesk AutoCAD Map 3D 2016 Service Pack 2:
MAPTOACAD
  • XData is missing after MAPTOACAD.
Display Manager
  • Layergroup is shown with gray check even if no layers under it are turned on.
FDO WMS
  • Letters with accents are not shown correctly in WMS Feature Information dialog.
Industry Model
  • Feature labels are not displayed in Job Explorer.
  • About Electrical Industry Model, when the Reconfigure Circuit and Flow workflow is run and encounters a transformer where the input circuit is not the same as the output circuit, the trace stops and the input circuit is unchanged.
  • Locked jobs in Autodesk Infrastructure Admin cannot be accessed after a crash.
  • Map 3D crashed when Overhead Transformer of Electric Industry Model is moved or rotated.
  • After Map 3D 2016 SP1 is applied, user cannot create labels with IM Form.
  • Opening some particluar file-based industry model drawing resulted in Autodesk Infrastructure Admin crash.
  • "TB_VARIABLE" with user id set does not work on Oracle Standard Edition.
Others
  • The installation problem of Map 3D 2016 service pack side by side with AutoCAD 2016 service pack.
  • Some security issue which may be caused by raster images.
