Update 5 pro Revit 2016 R2
Název fóra: Revit, BIM
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=22828
Datum vytištění: 21.zář.2026 v 22:20
Téma: Update 5 pro Revit 2016 R2
Předmět: Update 5 pro Revit 2016 R2
Datum odeslání: 02.čer.2016 v 08:54
Byla uvedena nová aktualizace - Update 5 - pro Autodesk Revit 2016 R2. Ke stažení přes Desktop App nebo na stránce Download. Přehled oprav:
Update 5 for Release 2
Platform
  • Export DWG/DXF/DWF
    • Corrects an issue causing block references to appear offset in DWG exports.*
  • Families
    • Corrects the positioning of shared nested family instances in a host family when there is more than one constraint to the nested instance .*
  • Schedules
    • Fixes an issue which caused Revit to freeze when editing a text parameter in a schedule if the drop-down list contains an empty line.*
  • Upgrade
    • Improves stability when upgrading or auditing projects which contain corrupt data .*
    • Improves stability when upgrading central model from Revit 2015 within Revit 2016 with German language specified.*
  • Worksharing
    • Improves stability when reloading links within workshared projects.*
  • Platform
    • Families
    • Schedules
    • Upgrade
    • Worksharing
