Vydán hotfix Civil 3D 2016.0.5
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=28512
Datum vytištění: 16.srp.2026 v 12:11
Téma: Vydán hotfix Civil 3D 2016.0.5
Předmět: Vydán hotfix Civil 3D 2016.0.5
Datum odeslání: 06.bře.2019 v 14:43
Byl vydán hotfix pro starší verzi Civilu - AutoCAD Civil 3D 2016.0.5 Update. K dispozici je na Autodesk Account. Obsahuje menší opravy: - Civil 3D no longer closes unexpectedly drawing a circle using a some linetypes.
- An issue has been resolved that resulted in annotations along parcel segments to be created incorrectly.
- As issue that resulted in lines to display inconsistently after using the REGEN or REGENALL command has been resolved.
- An issue where linetypes are not scaled as expected when an alignment mask is used has been resolved.
- When importing an expression into a drawing, and issue where the expression is not updated if the expression already exists in the destination has been resolved.
- An issue where the <[Source Object Name]> label property would display point numbers instead of point names for projection labels on section views has been resolved.
- An issue with the curb inlet calculation in sag in Hydraflow Storm Sewers and Hydraflow Express has been resolved.
------------- Vladimír Michl (moderátor) ARKANCE CZ - https://arkance.world - arkance.world (podpora viz emea.support.arkance.world)
