Aktualizace Inventor 2020.0.1
Název fóra: Inventor
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=28868
Datum vytištění: 03.lis.2026 v 13:29
Téma: Aktualizace Inventor 2020.0.1
Předmět: Aktualizace Inventor 2020.0.1
Datum odeslání: 16.kvě.2019 v 21:53
Byla vydána první aktualizace pro Inventor 2020 a Inventor LT 2020 - opravuje některé drobnější chyby. Ke stažení je v Autodesk Desktop App a v Account.
Přehled oprav v 2020.0.1 Update:
Add-Ins - Content Center
Resolved an issue where the Content Center Search function didn't function in non-English Inventor builds. INVGEN-26558
Add-Ins - Frame Generator
Improved stability when using Frame Generator Notch, Miter, and the Lengthen commands. INVGEN-28164
Add-Ins - Simulation - Dynamic Simulation
Improved performance when working with Dynamic Simulation to create data using the VBA API GetResultValues. INVGEN-27975
Assemblies - Constraints-Joint-Assemble
Improved stability when placing a part from Content Center using iMates. INVGEN-28165
Assemblies - Design Views
Improved stability when closing a part file. INVGEN-26441
Drawings - Views
Improved stability when using the Break Alignment View command in a drawing. INVGEN-28163
Improved stability when using the drawing Replace Model Reference command after closing the source drawing file. INVGEN-26828
Improved stability when changing the view scale in an auxiliary view. INVGEN-26438
ModX - Multi-Monitor
Improved stability when using multiple monitor configurations. INVGEN-27573
ModX - UI Framework
Resolved an issue where The Engineer's Notebook editor wouldn't recognize the keyboard [Space] and [Enter] functions. INVGEN-26440
None
Update to Trademarks and Copyright documentation. INVGEN-28263
Parts - 2D Sketch
Improved stability when creating a sketch in a part file. INVGEN-28160
Parts - Hole-Threads
Improved stability when creating a hole using an expression to offset the hole in the Y direction. INVGEN-28162
Parts - iFeature-iPart
Improved stability when using iLogic to update an assembly with a different parameter. INVGEN-28161
Platform - Framework - Licensing
Resolved an issue where Inventor would occasionally hang when running SUBSCRIBE NOW process. INVGEN-28325
Resolved an issue where Inventor wasn't able to retrieve the network license from a deployment install. INVGEN-27202
Platform - RSE
Improved stability when closing a file. INVGEN-28134
Odeslal: Ľubomír Pápay
Datum odeslání: 17.kvě.2019 v 09:59
Hm...však to nefunguje....alebo je u mňa niečo zle?
Ľubomír Pápay
Inventor 2009,2012
Datum odeslání: 21.kvě.2019 v 09:30
Pekny den p. Michl,
ten Update INV 2020 je v poriadku...?
Snazim sa ho stiahnut cez Autodesk Account, ale nejde to...
Ľubomír Pápay
Inventor 2009,2012
Datum odeslání: 21.kvě.2019 v 09:33
To je divné, v Accounts je vidět, v Desktop App také - jsou tam verze pro Inventor, Inventor LT a Inventor View 2020.
Datum odeslání: 21.kvě.2019 v 09:44
Ano, ja to tam vidím, ale nejde to stiahnuť...Ani napríklad tie Factory Design Utilities...čo sú tam....Ale napríklad už update pre 3D plant už ide...
Mne to namiesto sťahovania nen súbor otvorí akoby v nejakom textovom prehliadači...
Ľubomír Pápay
Inventor 2009,2012
Datum odeslání: 21.kvě.2019 v 09:57
Aha, to vypadá na nějaký problém ve web prohlížeči. Zkuste kliknout pravým tlačítkem a dát Save As/Uložit jako. Stahovaný soubor je typu .MSP (Microsoft Installer Patch).
Datum odeslání: 21.kvě.2019 v 10:28
Ano, takto to dovolí stiahnuť...
ďakujem
Ľubomír Pápay
Inventor 2009,2012
