Aktualizace FeatureCAM 2020.0.2
Název fóra: CAM, 3D tisk a ReCap
Popis fóra: CAM aplikace Autodesk, aditivní výroba a 3D tisk - Inventor CAM(HSM), HSMworks, PowerMill, FeatureCAM, Netfabb; reality-capture nástroje (mračna bodů, foto, 3D sken), aplikace ReCap
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=29139
Datum vytištění: 24.zář.2026 v 09:26
Téma: Aktualizace FeatureCAM 2020.0.2
Předmět: Aktualizace FeatureCAM 2020.0.2
Datum odeslání: 15.čvc.2019 v 18:47
Byl uveden update CAM aplikace Autodesk FeatureCAM 2020.0.2. Ke stažení je v účtu Autodesk Account.
Přehled oprav:
| Opening and saving files |
| Restored the ability to read older 32-bit part files (.fm, .mf,
.tsf, .md). When saved, the new version of the file will be 64-bit. FCAM-4142 |
| Milling |
| Fixed an issue in which milling features were created facing the wrong direction in some cases when using Index about Y. FCAM-3814 |
| Turning |
| Fixed an issue in which an ID backface groove feature did not cut correctly in some specific geometry cases. FCAM-1442 |
| Tools |
| Fixed an issue in which the Tool Holder Properties dialog did not update the preview picture when changing dimensions. FCAM-4217 |
| Enhanced the preview for the new Shell Mill holder type to show a boss on the end. FCAM-4219 |
| Fixed an issue in which comments on a tool holder did not save properly, depending on how the dialog was accessed. FCAM-4250 |
| Simulation |
| Fixed an issue in which the Z position displayed in the simulation
status bar was incorrect when setting the B-axis tool orientation
(flashing). FCAM-4209 |
| Fixed an issue in which FeatureCAM could exit unexpectedly when launching simulation in some specific cases. FCAM-4252 |
| Importing files |
| Fixed an issue in which some color information could be missing when imported from STEP files after version 2019.1.1. FCAM-4248 |
| Updated to support version 8.6 of the Autodesk Translation Framework for file import. FCAM-4341 |
------------- Vladimír Michl (moderátor) https://www.linkedin.com/in/vmichl/ - LinkedIn , Autodesk Expert Elite
