Byly vydány dvě aktualizace pro Autodesk Inventor - Update 2019.4.3 a Update 2018.3.8. Ke stažení jsou na Autodesk Account nebo přes Desktop App.
Update 2019.4.3 opravuje problém s ikonkami v Obsahovém centru po aktualizaci Windows 10 a další menší chyby.
Opravy 2019.4.3
| Add-Ins - Content Center |
| Resolved issue where Content Center category icons would go missing after installing Windows 10 update KB4517389. INVGEN-34445 |
| Add-Ins - Tube and Pipe |
| Resolved an issue where Enter Angle command is not shown in context menu for Tube and Pipe. INVGEN-34287 |
| Assemblies - Derived-Shrinkwrap |
| Improved stability when updating Derived Part file. INVGEN-34460 |
| Assemblies - Substitute |
| Resolved an issue where Hole Patching "All" option does not retain Representation View in Derived Assembly. INVGEN-33866 |
| Assemblies - Weldments |
| Resolved an issue where after running a weldbead report the weldment
assembly would no longer have a volume override in the physical
properties dialog. INVGEN-34458 |
| Drawings - Annotations |
| Resolved an issue where dragging a weld symbol resulted in unexpected behavior. INVGEN-29625 |
| Drawings - Annotations - Balloon |
| Improved performance of call-out symbols (balloons) when drawing is
opened with Defer Updates option or is disconnected with the model. INVGEN-34448 |
| Drawings - Views |
| Resolved issue with the drawing view scale changing unexpectedly
when editing, and the scale factor was not listed in the preset value. INVGEN-33861 |
| Resolved issue where drawing files displayed differently when opened in Inventor 2014 and Inventor 2018 or later. INVGEN-33863 |
| Resolved issue causing a performance issue with updating a drawing in R2019. INVGEN-34365 |
| Parts - 2D Sketch |
| Region Properties are now calculated accurately. INVGEN-23249 |
| Translators - DWG-DXF |
| Improved material indexing when importing DWG file as DXF. INVGEN-34398 |
| UI - Browser |
| Improved stability for UI Browser calls in API. INVGEN-33919 |
Opravy 2018.3.8
Sestavy – odvozený obal
- Byla zlepšena stabilita při aktualizaci souboru odvozené součásti. (INVGEN-34244)
------------- Vladimír Michl (moderátor) https://www.linkedin.com/in/vmichl/ - LinkedIn , Autodesk Expert Elite
