Byla uvolněna aktualizace Autodesk Civil 3D 2020.5.1. Ke stažení je na Autodesk Account nebo přes Desktop App.
Seznam nových funkcí a oprav:
https://help.autodesk.com/view/CIV3D/2020/ENU/?guid=Civil3D_ReleaseNotes_2020_5_Release_Notes_html" rel="nofollow - https://help.autodesk.com/view/CIV3D/2020/ENU/?guid=Civil3D_ReleaseNotes_2020_5_Release_Notes_html
| General |
| Fixed an issue in which synchronizing a pipe network data reference would incorrectly update the pipe and structure names with the pipe network name. | | Fixed an issue in which a data referenced alignment that was used as a reference for a pipe network was not updated after the alignment name was updated in the source drawing. | | Fixed an issue in which the reference surface name for a pipe was not updated in a host drawing after the surface name was updated in the source drawing. | | Fixed a stability issue that occurred when opening the Layer Palette if a reference template was attached to the drawing and the AeccRefTemplateAutoUpdate system variable was set to 2. | | Fixed an issue in which data shortcut reference data was not updated after using the Repair Broken Shortcuts command if the source was changed before repairing the data shortcuts. | | Fixed an issue in which the Prospector and Settings tabs could not be displayed again after turning them off. Fixed an issue in which the Prospector and Settings tabs were unexpectedly shown again when Civil 3D was restarted after turning them off. |
