Inventor Nastran 2021.2
Název fóra: Simulation, CFD, CAE
Popis fóra: Otázky k CAE aplikacím pro simulace a analýzy, Autodesk Simulation, CFD, Moldflow, Sim Studio, Simulation Composite, Robot Structural Analysis, Flow Design
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=31284
Datum vytištění: 30.říj.2026 v 19:31
Téma: Inventor Nastran 2021.2
Předmět: Inventor Nastran 2021.2
Datum odeslání: 17.lis.2020 v 21:44
Byla uvedena aktualizace simulační aplikace Autodesk Inventor Nastran 2021.2. Ke stažení je na Autodesk Account nebo přes Desktop App. Přináší především podstatně zvýšený výkon meshování 3D modelu.
Přehled novinek a oprav:
Meshing improvement
The cause of some crashes has been fixed, and the time required to mesh parts has been reduced by about 50%.
Post-processing performance improvement
Less time is required for post-processing activities such as animation and changing the results displayed.
Entering Inventor Nastran improvement
Complex models with midsurface/offset surfaces and multiple idealizations were often slow to open in Inventor Nastran, but performance in this area has been improved.
Helius PFA support
Helius PFA 2019 is now supported in Inventor Nastran.
iLogic improvement
A function has been added to the Nastran API that takes the key Context (either String or Byte Array) as input and returns the Nastran PersistID, which we can use for creating constraints, loads etc. without having to enter Nastran Environment.
