Vydán Revit 2021.1.2 (hotfix)
Název fóra: Revit, BIM
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=31288
Datum vytištění: 28.srp.2026 v 10:41
Téma: Vydán Revit 2021.1.2 (hotfix)
Předmět: Vydán Revit 2021.1.2 (hotfix)
Datum odeslání: 19.lis.2020 v 06:33
Autodesk uvolnil celkem rozsáhlý hotfix pro Revit 2021.1. K dispozici na Autodesk Account nebo přes Desktop App.
Přehled aktualizací a oprav (popis zatím jen anglicky):
Software embedded in the update executable:
Revit 2021 - version 21.1.20.44
Revit Unit Schemas 2021 - version 21.1.20.44
Steel Connections Content for Dynamo 2021 - version 2.6
Cloud Models for Revit 2021 - version 21.1.20.44
Generative Design for Revit 2021 - version 21.9.4.0
Personal Accelerator for Revit - version 22.0.1.0
OpenStudio - version 0.1.17
Issues Resolved
Annotation - Tags
Improved the stability when selecting material tags in 3D, section, or elevation views.
DirectShape Elements
Improved Massing instances imported from FormIt to dimension properly.
Energy - Analytical Model
Fixed an issue that caused systems analysis to fail if an analytical surface is created without a valid analytical space reference.
Export DWG/DXF
Improved the stability when exporting to DWG in a location synced to a cloud storage service.
Fabrication - MEP
Fixed an issue with elevation tags that would display ? when removing the leader from the tag.
Fixed an issue where thousand of combination was causing Revit to freeze during a reload configuration.
Family
Fixed the issue that families cannot be loaded if they are accompanied by a type catalog where types are separated by blank lines.
File Open/Save
Improved stability for model open when a registry item is lost.
Help
Fixed the issue that F1 keys do not display the correct help page in browser.
MEP Electrical Cable Tray and Conduit
Fixed an issue that caused cable tray fittings to not display in a plan view with annotation scale turned on.
MEP Electrical Circuits
Improved stability when creating a circuit in system browser after delete a circuit in canvas.
MEP Mechanical Other
Fixed an issue that caused a hosted element to move when its workset changed.
MEP P&ID Modeler
Allow user to associate a BIM 360 Plant Project on BIM 360 Docs via P&ID modeler when the model was originally associated with a Plant Project on A360 Teams.
Revit Cloud Worksharing
Fixed an issue so that sync with central would not be blocked by the long file path of a linked file in a cloud model or a Revit Server model.
Fixed an issue that a cloud model with name length close to limit 255 causes failure of navigating to the corresponding folder on Import/Link RVT dialog.
Fixed an issue when the Worksets are not editable task dialog is shown, when there are 2 users, both of whom created new worksets and edited their respective worksets, and then performed a SWC respectively, causing a Workset clash due to new worksets being downloaded into their locals during SWC.
