Using AI in Inventor - Autodesk Assistant
Kategorie: ARKANCE/CAD Studio
Název fóra: RSS kanály
Popis fóra: Automaticky publikované informace z dalších web služeb
URL: https://www.cadforum.cz/forum/forum_posts.asp?TID=35991
Datum vytištění: 17.říj.2026 v 15:10
Téma: Using AI in Inventor - Autodesk Assistant
Odeslal: YouTube RSS
Předmět: Using AI in Inventor - Autodesk Assistant
Datum odeslání: 10.čvc.2026 v 06:56
http://www.youtube.com/watch?v=xrnWDE7fRPw'>videohttp://www.youtube.com/watch?v=xrnWDE7fRPw'>
Adding Model states with Autodesk Inventor AI Assistant. Additional model states are added based on the 3 flange standard tables. The parametric model already has parameters that can be modified with the table values. The AI prompt for the Autodesk Assistant is: "I would like to help adding model states to the open part file. I have 3 tables in an Excel spreadsheet for different flange sizes based on the Flange standard and inch bore sizes. The tables are as follows..." {copy-paste-from-Excel} "Please create a new flange model state for each flange option. The model states should be labelled as "Flange Standard" - "Inch bore size". The iProperties for each model state should also update as follows... 1. Part Number should be Current part number + "Flange Standard"-"Inch Bore" 2. The Stock Number should be "Flange Standard"-"Inch Bore" 3. The Description should read: "Interface flange body to suit" "Flange Standard"-"Inch Bore" "(mm bore)" "Flange." See: https://ukcommunity.arkance.world/hc/en-us/articles/37023711271698-Automate-your-Inventor-designs-with-the-AI-based-Autodesk-Assistant https://www.cadforum.cz/en/autodesk-assistant-in-inventor-ai-powered-automation-for-model-tip15091 https://www.cadforum.cz/cz/autodesk-assistant-v-inventoru-automatizace-stavu-modelu-ai-tip15092 More on: https://arkance.world and https://www.cadforum.cz Contact: info.cz@arkance.world Follow us on: https://www.facebook.com/ArkanceCZ and https://www.linkedin.com/company/Arkance #arkance
10.07.2026 6:56:35
Viz http://www.youtube.com/watch?v=xrnWDE7fRPw - pokračování...
http://www.youtube.com/CADstudioCZ - youtube.com/CADstudioCZ - video kanál CAD Studia
