  <title>CAD Forum discussion (EN) : Non-linear gradient</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : Non-linear gradient]]></description>
  <pubDate>Mon, 12 Oct 2026 00:18:05 +0000</pubDate>
  <lastBuildDate>Wed, 05 Feb 2014 12:54:58 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10017</WebWizForums:feedURL>
   <title><![CDATA[Non-linear gradient : Brilliant solution Mr. Cooper!...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25920&amp;title=nonlinear-gradient#25920</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 05.Feb.2014 at 12:54<br /><br />Brilliant solution Mr. Cooper!&nbsp; I'll have to make note of it.<br>]]>
   <pubDate>Wed, 05 Feb 2014 12:54:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25920&amp;title=nonlinear-gradient#25920</guid>
   <title><![CDATA[Non-linear gradient : Cheers Kent, I did approach it...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25917&amp;title=nonlinear-gradient#25917</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=442135">GerroffMe</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 05.Feb.2014 at 10:13<br /><br />Cheers Kent, I did approach it like that and it worked great. I was hoping there would be easier/quicker way, but this way although a bit time consuming did work well.&nbsp;<div><br></div><div>Cheers for your response.</div>]]>
   <pubDate>Wed, 05 Feb 2014 10:13:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25917&amp;title=nonlinear-gradient#25917</guid>
   <title><![CDATA[Non-linear gradient : How about an approach like this?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25913&amp;title=nonlinear-gradient#25913</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 04.Feb.2014 at 20:30<br /><br />How about an approach like this?&nbsp; You can vary the proportions between the two areas, or use more than two areas if that gets you the look you want.&nbsp; Just make sure the "end" color of one gradient is the same as the "start" color of the next one.<DIV>&nbsp;</DIV><DIV><img src="http://www.cadforum.cz/forum_en/uploads/353260/2stageGradient.png" height="441" width="485" border="0" /></DIV>]]>
   <pubDate>Tue, 04 Feb 2014 20:30:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25913&amp;title=nonlinear-gradient#25913</guid>
   <title><![CDATA[Non-linear gradient : Oh actually I misunderstood you,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25911&amp;title=nonlinear-gradient#25911</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=442135">GerroffMe</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 04.Feb.2014 at 15:21<br /><br />Oh actually I misunderstood you, I have already attached the image, as I am tracing it. I cannot use the original image for the gradient because I need it to be compatible with other pieces of software, therefore it all needs to recreated purely using cad and not the original image.]]>
   <pubDate>Tue, 04 Feb 2014 15:21:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25911&amp;title=nonlinear-gradient#25911</guid>
   <title><![CDATA[Non-linear gradient : Would you be able to elaborate...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25909&amp;title=nonlinear-gradient#25909</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=442135">GerroffMe</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 04.Feb.2014 at 15:16<br /><br />Would you be able to elaborate a bit on the process, I am not familiar with that command.]]>
   <pubDate>Tue, 04 Feb 2014 15:16:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25909&amp;title=nonlinear-gradient#25909</guid>
   <title><![CDATA[Non-linear gradient : Their logos are .BMP files, which...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25907&amp;title=nonlinear-gradient#25907</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 04.Feb.2014 at 15:14<br /><br /><P>Their logos are .BMP files, which is one of the file types supported in AutoCAD's IMAGEATTACH command, so you can just insert one that way into an AutoCAD drawing.</P>]]>
   <pubDate>Tue, 04 Feb 2014 15:14:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25907&amp;title=nonlinear-gradient#25907</guid>
   <title><![CDATA[Non-linear gradient : GR_LINEAR gives a linear gradient,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25893&amp;title=nonlinear-gradient#25893</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=442135">GerroffMe</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 03.Feb.2014 at 13:13<br /><br />GR_LINEAR gives a linear gradient, however I am looking for a non-linear one, i.e. a gradient that is logarithmic that starts off dark, gets suddenly lighter and then from the middle point starts getting lighter slower and slower.&nbsp;<div><br></div><div><br></div>]]>
   <pubDate>Mon, 03 Feb 2014 13:13:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25893&amp;title=nonlinear-gradient#25893</guid>
   <title><![CDATA[Non-linear gradient :  Just pick the two &amp;#034;extreme&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25892&amp;title=nonlinear-gradient#25892</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 03.Feb.2014 at 13:06<br /><br />Just pick the two "extreme" colors - e.g. Color 152 and White and use the GR_LINEAR gradient with 90Â° angle.]]>
   <pubDate>Mon, 03 Feb 2014 13:06:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25892&amp;title=nonlinear-gradient#25892</guid>
   <title><![CDATA[Non-linear gradient : Hi all,I am trying to recreate...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25891&amp;title=nonlinear-gradient#25891</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=442135">GerroffMe</a><br /><strong>Subject:</strong> 10017<br /><strong>Posted:</strong> 03.Feb.2014 at 11:46<br /><br />Hi all,<div><br></div><div>I am trying to recreate a .dwg version of a logo for a company called RWE. Their logo has a gradient in it, but it does not appear to be a linear transition from dark to light. I have tried using the gradient/hatch feature but it has not given the desired results.&nbsp;</div><div><br></div><div>Does anyone have any recommendations how I can achieve an exact match for the gradient?</div><div><br></div><div>Here is the logo I am trying to recreate:&nbsp;</div><div><br></div><div><a href="https://www.google.co.uk/search?q=rwe&amp;safe=off&amp;espv=210&amp;es_sm=122&amp;source=lnms&amp;tbm=isch&amp;sa=X&amp;ei=mHLvUpC1NcSq7QaS1YH4Aw&amp;ved=0CAoQ_AUoAg&amp;biw=1920&amp;bih=1085#facrc=_&amp;imgrc=TBpUD18xHDpaHM%253A%3B_FSQzhJncE4PsM%3Bhttp%253A%252F%252Fwww.refitsmarthomes.org%252Fwp-content%252Fuploads%252F2012%252F08%252FRWE_UK_Logo_3C_P_M.jpg%3Bhttp%253A%252F%252Fwww.refitsmarthomes.org%252Findex.php%252Findustry-partners%252F%3B1108%3B561" target="_blank" rel="nofollow">https://www.google.co.uk/search?q=rwe&amp;safe=off&amp;espv=210&amp;es_sm=122&amp;source=lnms&amp;tbm=isch&amp;sa=X&amp;ei=mHLvUpC1NcSq7QaS1YH4Aw&amp;ved=0CAoQ_AUoAg&amp;biw=1920&amp;bih=1085#facrc=_&amp;imgrc=TBpUD18xHDpaHM%253A%3B_FSQzhJncE4PsM%3Bhttp%253A%252F%252Fwww.refitsmarthomes.org%252Fwp-content%252Fuploads%252F2012%252F08%252FRWE_UK_Logo_3C_P_M.jpg%3Bhttp%253A%252F%252Fwww.refitsmarthomes.org%252Findex.php%252Findustry-partners%252F%3B1108%3B561</a></div><div><br></div><div><br></div>]]>
   <pubDate>Mon, 03 Feb 2014 11:46:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10017&amp;PID=25891&amp;title=nonlinear-gradient#25891</guid>
