  <title>CAD Forum discussion (EN) : Preview Pane</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Preview Pane]]></description>
  <pubDate>Wed, 04 Nov 2026 14:23:34 +0000</pubDate>
  <lastBuildDate>Fri, 28 Feb 2014 12:26:45 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10080</WebWizForums:feedURL>
   <title><![CDATA[Preview Pane : Well? Did you get it to work? ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26203&amp;title=preview-pane#26203</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10080<br /><strong>Posted:</strong> 28.Feb.2014 at 12:26<br /><br />Well?&nbsp; Did you get it to work?<br>]]>
   <pubDate>Fri, 28 Feb 2014 12:26:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26203&amp;title=preview-pane#26203</guid>
   <title><![CDATA[Preview Pane : This is what needs to be changed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26195&amp;title=preview-pane#26195</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10080<br /><strong>Posted:</strong> 27.Feb.2014 at 13:53<br /><br />This is what needs to be changed in order to get a thumbnail preview.<br><br>\\HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R<font color="blue">xx.x</font>\ACAD-<font color="blue">xxxxxx</font>\Profiles\<font color="blue">Profile_Name</font>\Dialogs\Select File.<br><br>Set the DWORD "PreviewVisible" to <b><font color="#FF0000">1</font></b>;; the <font color="blue">blue parts</font> vary depending on your system, version, and profile name.<br><br>I tested this today (Feb 27) and it does work. <br><span style="font-size:10px"><br /><br />Edited by John Connor - 27.Feb.2014 at 14:10</span>]]>
   <pubDate>Thu, 27 Feb 2014 13:53:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26195&amp;title=preview-pane#26195</guid>
   <title><![CDATA[Preview Pane : You may have a setting (hexidecimal)...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26193&amp;title=preview-pane#26193</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10080<br /><strong>Posted:</strong> 26.Feb.2014 at 23:53<br /><br />You may have a setting (hexidecimal) in the Windows Registry that needs to be reset.<br><br>Have you ever edited the Registry?<br>]]>
   <pubDate>Wed, 26 Feb 2014 23:53:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26193&amp;title=preview-pane#26193</guid>
   <title><![CDATA[Preview Pane : How do you re-install the Preview...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26191&amp;title=preview-pane#26191</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=449022">ltcustomdesigner</a><br /><strong>Subject:</strong> 10080<br /><strong>Posted:</strong> 26.Feb.2014 at 21:01<br /><br />How do you re-install the Preview Pane when you open a drawing file. &nbsp;It is already ticked on the Options...<div>but still nothing shows up on the right hand corner.</div><div><br></div><div><br></div><div>Thanks in advacne</div>]]>
   <pubDate>Wed, 26 Feb 2014 21:01:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10080&amp;PID=26191&amp;title=preview-pane#26191</guid>
