  <title>CAD Forum discussion (EN) : drafting with more efficiency</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : drafting with more efficiency]]></description>
  <pubDate>Fri, 04 Sep 2026 06:22:31 +0000</pubDate>
  <lastBuildDate>Fri, 02 May 2014 23:33:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10100</WebWizForums:feedURL>
   <title><![CDATA[drafting with more efficiency : ALIASEDITWas always a pretty simple...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=27020&amp;title=drafting-with-more-efficiency#27020</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=423875">pweeks</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 02.May.2014 at 23:33<br /><br />ALIASEDIT<br><br>Was always a pretty simple and easy way for me to edit my hot keys.<br>]]>
   <pubDate>Fri, 02 May 2014 23:33:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=27020&amp;title=drafting-with-more-efficiency#27020</guid>
   <title><![CDATA[drafting with more efficiency : Edit your CUIx. The procedure...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26990&amp;title=drafting-with-more-efficiency#26990</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 30.Apr.2014 at 11:37<br /><br />Edit your CUIx.&nbsp; The procedure is outlined in your Customization file.<br>]]>
   <pubDate>Wed, 30 Apr 2014 11:37:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26990&amp;title=drafting-with-more-efficiency#26990</guid>
   <title><![CDATA[drafting with more efficiency :  how to modify the shortcut keys...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26982&amp;title=drafting-with-more-efficiency#26982</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=466984">YOCAD</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 30.Apr.2014 at 02:35<br /><br /><span id="result_" ="short_text" lang="en"><span ="hps">how to</span> <span ="hps">modify the</span> <span ="hps">shortcut keys on autocad2013 ?<br></span></span>]]>
   <pubDate>Wed, 30 Apr 2014 02:35:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26982&amp;title=drafting-with-more-efficiency#26982</guid>
   <title><![CDATA[drafting with more efficiency : I suggest to modify the &amp;#034;acad.pgp&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26607&amp;title=drafting-with-more-efficiency#26607</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=455019">kadar</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 19.Mar.2014 at 07:41<br /><br />I suggest to modify the "acad.pgp" file and tailor it according to your convenience.<br>You can modify the shortcut keys to suit to your left hand's convenience.<br>Example. <br>D,&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; *DIMLINEAR<br>DD,&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; *DIMALIGNED<br>DDD,&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; *DIMANGULAR<br><br>]]>
   <pubDate>Wed, 19 Mar 2014 07:41:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26607&amp;title=drafting-with-more-efficiency#26607</guid>
   <title><![CDATA[drafting with more efficiency : Check out the BeamLineLabel.lsp...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26482&amp;title=drafting-with-more-efficiency#26482</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 12.Mar.2014 at 14:06<br /><br /><P>Check out the BeamLineLabel.lsp routine here:</P><DIV></DIV><a href="http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Lisp-Request-Pline-Beams/m-p/4762867/highlight/true#M318626" target="_blank" rel="nofollow">http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Lisp-Request-Pline-Beams/m-p/4762867/highlight/true#M318626</A><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>That makes Polylines with width, because that's what the poster was looking for.&nbsp; I also have one that makes Lines instead, if you prefer.</DIV>]]>
   <pubDate>Wed, 12 Mar 2014 14:06:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26482&amp;title=drafting-with-more-efficiency#26482</guid>
   <title><![CDATA[drafting with more efficiency : Have you used TRIM with Select...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26464&amp;title=drafting-with-more-efficiency#26464</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 12.Mar.2014 at 08:41<br /><br />Have you used TRIM with Select All (in other words, type TRIM at the command line.&nbsp; Then when prompted for what to use as trimming lines simply hit the &lt;enter&gt; key.&nbsp; This selects everything in the drawing.&nbsp; From there you can jump throughout the drawing trimming everything you need to.<br><br>This idea allows you to very quickly draw without worrying about getting everything correct... just make sure the lines are longer than they need to and cross other lines.&nbsp; Then go back and trim later.<br><br>Dave.<br>]]>
   <pubDate>Wed, 12 Mar 2014 08:41:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26464&amp;title=drafting-with-more-efficiency#26464</guid>
   <title><![CDATA[drafting with more efficiency : yep, the dashed lines are the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26326&amp;title=drafting-with-more-efficiency#26326</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=451107">justanotherryan</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 06.Mar.2014 at 01:13<br /><br />yep, the dashed lines are the "headers" of which i speak.&nbsp;<div>i wouldn't say im "having trouble" drawing them, i just don't want to waste time drawing each one. Remember, im aiming for efficiency.</div><div><br></div><div>that sounds like a great solution. i'll have to look up how to do that.</div><div>thanks John</div><div><br></div>]]>
   <pubDate>Thu, 06 Mar 2014 01:13:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26326&amp;title=drafting-with-more-efficiency#26326</guid>
   <title><![CDATA[drafting with more efficiency : Are you talking about the dashed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26325&amp;title=drafting-with-more-efficiency#26325</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 06.Mar.2014 at 00:38<br /><br />Are you talking about the dashed line that overruns the two small solid lines like where a window or door might be located?&nbsp; You're having a problem drawing those??<br><br>OK...the solution is to make the header a dynamic block with a stretch option.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 06.Mar.2014 at 00:53</span>]]>
   <pubDate>Thu, 06 Mar 2014 00:38:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26325&amp;title=drafting-with-more-efficiency#26325</guid>
   <title><![CDATA[drafting with more efficiency :  well that was more trouble than...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26324&amp;title=drafting-with-more-efficiency#26324</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=451107">justanotherryan</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 06.Mar.2014 at 00:32<br /><br /><img src="uploads/451107/headers1.JPG" height="503" width="588" border="0" /><img src="uploads/451107/headers2.JPG" height="477" width="833" border="0" /><div><br></div><div><br></div><div><br></div><div>well that was more trouble than it was worth.&nbsp;</div><div>any ways here is what i mean&nbsp;</div><div><br></div>]]>
   <pubDate>Thu, 06 Mar 2014 00:32:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26324&amp;title=drafting-with-more-efficiency#26324</guid>
   <title><![CDATA[drafting with more efficiency : Post an image so I can narrow...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26323&amp;title=drafting-with-more-efficiency#26323</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10100<br /><strong>Posted:</strong> 06.Mar.2014 at 00:11<br /><br />Post an image so I can narrow down the choices.&nbsp; What about the STRETCH command?&nbsp; No trimming and no extending.<br>]]>
   <pubDate>Thu, 06 Mar 2014 00:11:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10100&amp;PID=26323&amp;title=drafting-with-more-efficiency#26323</guid>
