  <title>CAD Forum discussion (EN) : Civil 3D Running really slow</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : Civil 3D Running really slow]]></description>
  <pubDate>Thu, 01 Oct 2026 16:20:47 +0000</pubDate>
  <lastBuildDate>Wed, 12 Mar 2014 07:51:59 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10116</WebWizForums:feedURL>
   <title><![CDATA[Civil 3D Running really slow :  The certification itself maybe...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26461&amp;title=civil-3d-running-really-slow#26461</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 10116<br /><strong>Posted:</strong> 12.Mar.2014 at 07:51<br /><br />The certification itself maybe doesn't matter but the resulting disabled hardware acceleration does matter a lot. With 16 gigs of RAM, I think AutoCAD doesn't need too many hard disk read/writes. The TURBO utility would show of it is only a problem of AutoCAD configuration settings or a system problem.]]>
   <pubDate>Wed, 12 Mar 2014 07:51:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26461&amp;title=civil-3d-running-really-slow#26461</guid>
   <title><![CDATA[Civil 3D Running really slow :   Vladimir Michl wrote: Unfortunately...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26460&amp;title=civil-3d-running-really-slow#26460</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=249910">Novarese</a><br /><strong>Subject:</strong> 10116<br /><strong>Posted:</strong> 12.Mar.2014 at 07:36<br /><br /><p><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Vladimir Michl" alt="Originally posted by Vladimir Michl" style="vertical-align: text-bottom;" /> <strong>Vladimir Michl wrote:</strong><br /><br />Unfortunately your graphics card is not certified</td></tr></table></p><p>I guess it doesn't matter, sir.</p><p>One hour to create a simple profile is really too much, so I bet the OP has an hard disk issue (highly defragmented, no free space for TEMP files, and so on), or a network one (dead mapped drives, for instance).</p><p><img src="http://novarese.t15.org/smile.gif" border="0" /></p><p><br></p><span style="font-size:10px"><br /><br />Edited by Novarese - 12.Mar.2014 at 07:38</span>]]>
   <pubDate>Wed, 12 Mar 2014 07:36:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26460&amp;title=civil-3d-running-really-slow#26460</guid>
   <title><![CDATA[Civil 3D Running really slow :  You can also try the TURBO utility...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26429&amp;title=civil-3d-running-really-slow#26429</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 10116<br /><strong>Posted:</strong> 11.Mar.2014 at 08:23<br /><br />You can also try the TURBO utility - see Download and Tips.]]>
   <pubDate>Tue, 11 Mar 2014 08:23:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26429&amp;title=civil-3d-running-really-slow#26429</guid>
   <title><![CDATA[Civil 3D Running really slow :  Unfortunately your graphics...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26428&amp;title=civil-3d-running-really-slow#26428</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 10116<br /><strong>Posted:</strong> 11.Mar.2014 at 08:22<br /><br />Unfortunately your graphics card is not certified (not supported) in AutoCAD 2014 so you are running without hardware acceleration. See:<div><a href="http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&amp;id=18844534&amp;results=1&amp;stype=graphic&amp;product_group=3&amp;release=2014&amp;os=8192&amp;manuf=1&amp;opt=0" target="_blank" rel="nofollow">http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&amp;id=18844534&amp;results=1&amp;stype=graphic&amp;product_group=3&amp;release=2014&amp;os=8192&amp;manuf=1&amp;opt=0</a></div><div>&nbsp;</div><div>Try to manually switch on graphics acceleration (3DCONFIG).</div>]]>
   <pubDate>Tue, 11 Mar 2014 08:22:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26428&amp;title=civil-3d-running-really-slow#26428</guid>
   <title><![CDATA[Civil 3D Running really slow : Hey,I&amp;#039;m Runing C3D 2014,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26426&amp;title=civil-3d-running-really-slow#26426</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=452387">getrekd</a><br /><strong>Subject:</strong> 10116<br /><strong>Posted:</strong> 11.Mar.2014 at 00:57<br /><br /><span style=": rgb254, 253, 253; color: rgb102, 102, 102; font-family: FrutigerNextW04-Regular; font-size: 14px; line-height: 15px;">Hey,&nbsp;</span><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">&nbsp;</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">I'm Runing C3D 2014, &nbsp;It's just started running really slowly.. It takes me nearly an hour to create a quick profile from a polyline. Any suggestions on settings or do I have a bad install.. I`m sure my computer can handle this.&nbsp;</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">&nbsp;</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">Alienware MX17</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">Intel(R) Core i7-4930MX CPU at 3.00 GHZ</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">16.00 GB Ram&nbsp;</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">Windows 7 Ultimate 64 Bit</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">Ge Force GTX 780M Graphics card with 4.0 GB RAM</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">&nbsp;</p><p style="font-size: 14px; font-family: FrutigerNextW04-Regular; color: rgb102, 102, 102; margin: 0px; padding: 0px; line-height: 15px; : rgb254, 253, 253;">When I open task manager it only shows my 4.2GB of RAM Being used while processing which doesn`t make sense because it takes flipping forever to load anything!! Any Help is appreciated!&nbsp;</p>]]>
   <pubDate>Tue, 11 Mar 2014 00:57:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10116&amp;PID=26426&amp;title=civil-3d-running-really-slow#26426</guid>
