  <title>CAD Forum discussion (EN) : Arrowhead missing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Arrowhead missing]]></description>
  <pubDate>Wed, 30 Sep 2026 21:19:39 +0000</pubDate>
  <lastBuildDate>Sun, 16 Mar 2014 14:35:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10120</WebWizForums:feedURL>
   <title><![CDATA[Arrowhead missing : I&amp;#039;d like to know how it was...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26564&amp;title=arrowhead-missing#26564</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 16.Mar.2014 at 14:35<br /><br />I'd like to know how it was lost in the first place but I am glad the one I provided worked.&nbsp; Thanks for the update.<br>]]>
   <pubDate>Sun, 16 Mar 2014 14:35:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26564&amp;title=arrowhead-missing#26564</guid>
   <title><![CDATA[Arrowhead missing : Tried it and it works.Still would...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26562&amp;title=arrowhead-missing#26562</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=14977">PeterStanley</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 16.Mar.2014 at 12:48<br /><br />Tried it and it works.<div><br></div><div>Still would like to find out how to get the proper one back!</div>]]>
   <pubDate>Sun, 16 Mar 2014 12:48:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26562&amp;title=arrowhead-missing#26562</guid>
   <title><![CDATA[Arrowhead missing : Thanks.I&amp;#039;ll give that a try...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26481&amp;title=arrowhead-missing#26481</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=14977">PeterStanley</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 13:41<br /><br />Thanks.<div><br></div><div>I'll give that a try later.</div>]]>
   <pubDate>Wed, 12 Mar 2014 13:41:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26481&amp;title=arrowhead-missing#26481</guid>
   <title><![CDATA[Arrowhead missing : I uploaded a block named Right...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26478&amp;title=arrowhead-missing#26478</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 12:34<br /><br />I uploaded a block named Right Angle.dwg and placed it in the CAD Blocks section under Architecture &gt; _Other.<br><br>And here is a link about creating custom arrowheads and how to use them.<br><br>http://www.cadblog.net/creating-arrowheads.htm<br><br>Consider this your fall-back option.<br><br>Good luck.<br>]]>
   <pubDate>Wed, 12 Mar 2014 12:34:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26478&amp;title=arrowhead-missing#26478</guid>
   <title><![CDATA[Arrowhead missing : Options &amp;gt; Profile.Any of the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26476&amp;title=arrowhead-missing#26476</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 12:12<br /><br />Options &gt; Profile.<br><br>Any of the settings you access via the Options dialog box would be affected.<br><br>I thought all the arrowheads were blocks but I can't locate them.&nbsp; OK...so I went back into my drawing and changed to the Right Angle arrowhead and created a dimension.&nbsp; Then I exploded it.&nbsp; The Right Angle arrowhead is definitely a block but AutoDesk programmers thought that the name _Open90 was much more appropriate than Right Angle.&nbsp; Now that I know what to search for maybe I can find the damn thing.<br><br>Crap!&nbsp; Even with that bit of info I still could not find the block on my computer.<br><br>Well if you don't want to reset your Profile or do a REPAIR I could WBlock out the arrowhead and upload it here along with instructions on creating your own custom arrowhead which if you did do it I would use the name Right Angle and avoid using _Open90.<br><br>Got to step away from my desk for a while.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 12.Mar.2014 at 12:23</span>]]>
   <pubDate>Wed, 12 Mar 2014 12:12:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26476&amp;title=arrowhead-missing#26476</guid>
   <title><![CDATA[Arrowhead missing : How do I reset my profile and...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26475&amp;title=arrowhead-missing#26475</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=14977">PeterStanley</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 11:59<br /><br />How do I reset my profile and what else is that likely to affect?]]>
   <pubDate>Wed, 12 Mar 2014 11:59:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26475&amp;title=arrowhead-missing#26475</guid>
   <title><![CDATA[Arrowhead missing : Try resetting your Profile first....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26474&amp;title=arrowhead-missing#26474</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 11:56<br /><br />Try resetting your Profile first.&nbsp; If that doesn't work then you could do a REPAIR of the installation.&nbsp; <br><br>You could also recreate the right angle arrowhead yourself.<br>]]>
   <pubDate>Wed, 12 Mar 2014 11:56:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26474&amp;title=arrowhead-missing#26474</guid>
   <title><![CDATA[Arrowhead missing : This is not a new installation.The...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26473&amp;title=arrowhead-missing#26473</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=14977">PeterStanley</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 11:47<br /><br />This is not a new installation.<div><br></div><div>The right angle arrowhead has been in use previously and I have not tried to create a new arrowhead style.</div><div><br></div><div>Where are the arrowheads stored. Is it possible to import from another computer or can I repair my installation?</div>]]>
   <pubDate>Wed, 12 Mar 2014 11:47:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26473&amp;title=arrowhead-missing#26473</guid>
   <title><![CDATA[Arrowhead missing : There&amp;#039;s no real reason why...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26472&amp;title=arrowhead-missing#26472</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 11:37<br /><br />There's no real reason why any of the arrowhead styles that come standard with AutoCAD should be missing.&nbsp; Someone would have to intentionally delete it or there was a problem during the original installation of the program.&nbsp; <br><br>Is this a new install?<br><br>One other possibility.&nbsp; You didn't try creating a new arrowhead style by any chance did you?<br>]]>
   <pubDate>Wed, 12 Mar 2014 11:37:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26472&amp;title=arrowhead-missing#26472</guid>
   <title><![CDATA[Arrowhead missing : AutoCAD LT 2013 ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26471&amp;title=arrowhead-missing#26471</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=14977">PeterStanley</a><br /><strong>Subject:</strong> 10120<br /><strong>Posted:</strong> 12.Mar.2014 at 10:50<br /><br />AutoCAD LT 2013]]>
   <pubDate>Wed, 12 Mar 2014 10:50:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10120&amp;PID=26471&amp;title=arrowhead-missing#26471</guid>
