  <title>CAD Forum discussion (EN) : AutoCAD CUI</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : AutoCAD CUI]]></description>
  <pubDate>Sat, 05 Sep 2026 16:31:03 +0000</pubDate>
  <lastBuildDate>Tue, 13 May 2014 12:12:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10293</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD CUI : Hello Sysgen  Thank you for your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10293&amp;PID=27097&amp;title=autocad-cui#27097</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=364557">1616syd</a><br /><strong>Subject:</strong> 10293<br /><strong>Posted:</strong> 13.May.2014 at 12:12<br /><br /><FONT size=3>Hello Sysgen </FONT><DIV></DIV><FONT size=3>Thank you for your reply. </FONT><DIV></DIV><FONT size=3>However what I was looking for is not actually in the AutoCAD GUI itself, but written into the menu CUI. When a block is selected and you right click, the context menu displayed contains many options, and in particular:- </FONT><DIV></DIV><FONT size=3>'Edit Block In-place...'. After invoking CUI and searching the main customisation menu, I cannot find these menu items in the menu shortcuts. </FONT><DIV></DIV><DIV><FONT size=3>Kind regards Syd</FONT></DIV><DIV><FONT size=3></FONT>&nbsp;</DIV><DIV><FONT size=3></FONT>&nbsp;</DIV>]]>
   <pubDate>Tue, 13 May 2014 12:12:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10293&amp;PID=27097&amp;title=autocad-cui#27097</guid>
   <title><![CDATA[AutoCAD CUI : Hi SydA sample of shortcut menu...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10293&amp;PID=27096&amp;title=autocad-cui#27096</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=469827">sysgen</a><br /><strong>Subject:</strong> 10293<br /><strong>Posted:</strong> 13.May.2014 at 02:13<br /><br /><font size="3">Hi Syd&nbsp;</font><div><font size="3"><br></font></div><div><font size="3">A sample of shortcut menu you are trying to find.. just refer it to my</font></div><div><font size="3">screen shot.. thanks...</font></div><div><br></div><div><img src="http://forums.autodesk.com/autodesk/attachments/autodesk/706/31159/1/Rt%20Click.jpg" height="704" width="596" border="0" /><br></div><div><br></div><div><br></div><div><font face="Arial, Helvetica, sans-serif" size="3">best regards,</font></div><div><font face="Arial, Helvetica, sans-serif" size="3">Sysgen &nbsp;- <a href="http://www.sysgenoutsource.com" target="_blank" rel="nofollow">www.sysgenoutsource.com</a></font></div><div><br></div><div><br></div>]]>
   <pubDate>Tue, 13 May 2014 02:13:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10293&amp;PID=27096&amp;title=autocad-cui#27096</guid>
   <title><![CDATA[AutoCAD CUI : AutoCAD Architecture 2014 CUI....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10293&amp;PID=27092&amp;title=autocad-cui#27092</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=364557">1616syd</a><br /><strong>Subject:</strong> 10293<br /><strong>Posted:</strong> 12.May.2014 at 15:26<br /><br /><P style="MARGIN: 0cm 0cm 0pt" =MsoNormal><FONT size=3 face="Arial, Helvetica, sans-serif">AutoCAD Architecture 2014 CUI. Where is the shortcut menu</P><DIV>(which displays the context menu) </FONT></DIV><P style="MARGIN: 0cm 0cm 0pt" =MsoNormal><FONT size=3 face="Arial, Helvetica, sans-serif">for the 'Edit Block In-place'&nbsp;command.</P><DIV>&nbsp;</DIV><DIV>Syd (UK)</DIV></FONT>]]>
   <pubDate>Mon, 12 May 2014 15:26:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10293&amp;PID=27092&amp;title=autocad-cui#27092</guid>
