  <title>CAD Forum discussion (EN) : Inventor iPart Factory &amp; Vault</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : Inventor iPart Factory &amp; Vault]]></description>
  <pubDate>Tue, 21 Jul 2026 09:19:27 +0000</pubDate>
  <lastBuildDate>Thu, 15 May 2014 22:48:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10303</WebWizForums:feedURL>
   <title><![CDATA[Inventor iPart Factory &amp; Vault : I recently came across an error...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10303&amp;PID=27118&amp;title=inventor-ipart-factory-vault#27118</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=471767">fspialek</a><br /><strong>Subject:</strong> 10303<br /><strong>Posted:</strong> 15.May.2014 at 22:48<br /><br />I recently came across an error in an assembly where the dialogue is "Member row deleted from factory". The assembly is created by another user. When I insert as a sub-assembly into a new assembly the error does not show up right away; only after saving or updating the new assembly. Typically, I will just open the sub-assembly causing the error, check out the file from the vault, open the factory table and direct it to the correct reference. Then I would save and check in.<br><br>Here is the issue. The part is missing from the table, but I cannot just add a new row member since there are suppressed features. I could replace it with the wrong part (with wrong features for the sub-assembly). When the other user opens the sub-assembly there is no error. He believes there is a local copy of that instance on his hard drive. It is not in the vault, so it errors when the part is retrieved for other users.<br><br>1. What is a safe way to correct this conflicted reference without creating more problems between the vault and local copies?<br><br>2. How can the user with the local reference merge it back into the sub-assembly in the vault?<br>]]>
   <pubDate>Thu, 15 May 2014 22:48:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10303&amp;PID=27118&amp;title=inventor-ipart-factory-vault#27118</guid>
