  <title>CAD Forum discussion (EN) : autocad or autocad electrical</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : autocad or autocad electrical]]></description>
  <pubDate>Sat, 05 Sep 2026 05:02:51 +0000</pubDate>
  <lastBuildDate>Tue, 10 Jun 2014 15:37:01 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10370</WebWizForums:feedURL>
   <title><![CDATA[autocad or autocad electrical : MEP? Wouldn&amp;#039;t that be overkill...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27365&amp;title=autocad-or-autocad-electrical#27365</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10370<br /><strong>Posted:</strong> 10.Jun.2014 at 15:37<br /><br />MEP?&nbsp; Wouldn't that be overkill as well?&nbsp; Now, if he were drawing a electrical power substation or a chemical plant maybe MEP would be the way to go but not for a house.<br>]]>
   <pubDate>Tue, 10 Jun 2014 15:37:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27365&amp;title=autocad-or-autocad-electrical#27365</guid>
   <title><![CDATA[autocad or autocad electrical :  AutoCAD MEP would be probably...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27364&amp;title=autocad-or-autocad-electrical#27364</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 10370<br /><strong>Posted:</strong> 10.Jun.2014 at 15:27<br /><br />AutoCAD MEP would be probably the best option but any plain AutoCAD or even AutoCAD LT will do.]]>
   <pubDate>Tue, 10 Jun 2014 15:27:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27364&amp;title=autocad-or-autocad-electrical#27364</guid>
   <title><![CDATA[autocad or autocad electrical : Here is a link to an article that...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27359&amp;title=autocad-or-autocad-electrical#27359</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10370<br /><strong>Posted:</strong> 09.Jun.2014 at 13:17<br /><br />Here is a link to an article that you might find helpful.<br><br><b>Understanding a Residential Electrical Plan<br></b><br>http://homedesign.8m.com/articles/<br>]]>
   <pubDate>Mon, 09 Jun 2014 13:17:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27359&amp;title=autocad-or-autocad-electrical#27359</guid>
   <title><![CDATA[autocad or autocad electrical : It could easily be done in plain...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27353&amp;title=autocad-or-autocad-electrical#27353</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10370<br /><strong>Posted:</strong> 08.Jun.2014 at 20:05<br /><br />It could easily be done in plain AutoCAD.&nbsp; AutoCAD Electrical would, in my opinion, be massive overkill and a waste of money for a project like this.<br><br>You are basically drawing a floor plan that will show the location of all outlets, wall switches, overhead lights, wall mounted lights, fans and any specialty items like a garbage disposal or a wall mounted heater.&nbsp; You probably should specifically call out any GFI (ground fault interrupt) outlets.&nbsp; The only wires shown are those that go from a switch to the light or device that it controls.&nbsp; You do not need to show each and every wire in the house.<br>]]>
   <pubDate>Sun, 08 Jun 2014 20:05:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27353&amp;title=autocad-or-autocad-electrical#27353</guid>
   <title><![CDATA[autocad or autocad electrical : Can someone help me , i need to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27352&amp;title=autocad-or-autocad-electrical#27352</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=478150">herve88</a><br /><strong>Subject:</strong> 10370<br /><strong>Posted:</strong> 08.Jun.2014 at 15:05<br /><br />Can someone help me , i need to draw a house'electrical plan for the first time and i want to know which autocad must i use.&nbsp;<div>Thanks</div>]]>
   <pubDate>Sun, 08 Jun 2014 15:05:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10370&amp;PID=27352&amp;title=autocad-or-autocad-electrical#27352</guid>
