  <title>CAD Forum discussion (EN) : Export Block Attributes to CDF</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Export Block Attributes to CDF]]></description>
  <pubDate>Wed, 28 Oct 2026 08:51:18 +0000</pubDate>
  <lastBuildDate>Mon, 14 Jul 2014 17:45:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10458</WebWizForums:feedURL>
   <title><![CDATA[Export Block Attributes to CDF : I am aware of exporting block...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10458&amp;PID=27597&amp;title=export-block-attributes-to-cdf#27597</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=486490">mfkozlow</a><br /><strong>Subject:</strong> 10458<br /><strong>Posted:</strong> 14.Jul.2014 at 17:45<br /><br />I am aware of exporting block attributes to CDF files through the use of the ATTEXT command, however I would like to be able to accomplish this without actually opening AutoCAD Electrical 2014. Ideally I would like an excel sheet to fetch these attributes automatically, through the use of Macros, and import them into the spreadsheet without opening the program. Is there any possible way to do this, or a way to access drawing information through the .DWG file itself without the use of the AutoCAD software. Thanks.<br>]]>
   <pubDate>Mon, 14 Jul 2014 17:45:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10458&amp;PID=27597&amp;title=export-block-attributes-to-cdf#27597</guid>
