  <title>CAD Forum discussion (EN) : Coppy follow up</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Coppy follow up]]></description>
  <pubDate>Sat, 05 Sep 2026 06:30:51 +0000</pubDate>
  <lastBuildDate>Wed, 16 Jul 2014 23:41:47 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10463</WebWizForums:feedURL>
   <title><![CDATA[Coppy follow up : For the first task try the Measure...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27614&amp;title=coppy-follow-up#27614</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10463<br /><strong>Posted:</strong> 16.Jul.2014 at 23:41<br /><br />For the first task try the Measure command.&nbsp; As for the second I have no idea.<br>]]>
   <pubDate>Wed, 16 Jul 2014 23:41:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27614&amp;title=coppy-follow-up#27614</guid>
   <title><![CDATA[Coppy follow up : Let me explain you in a example....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27611&amp;title=coppy-follow-up#27611</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=483918">SamaonA</a><br /><strong>Subject:</strong> 10463<br /><strong>Posted:</strong> 16.Jul.2014 at 20:02<br /><br />Let me explain you in a example. &nbsp;Lets say I have a column, I want the Column to follow up a wavy curve every 7" gap,&nbsp;or&nbsp;have this column double few time with even gaps follow by the curve line. How do I do that?&nbsp;]]>
   <pubDate>Wed, 16 Jul 2014 20:02:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27611&amp;title=coppy-follow-up#27611</guid>
   <title><![CDATA[Coppy follow up : I&amp;#039;m not sure I understand...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27609&amp;title=coppy-follow-up#27609</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10463<br /><strong>Posted:</strong> 16.Jul.2014 at 18:12<br /><br />I'm not sure I understand your question.&nbsp; Have you tried the Measure or Divide commands?&nbsp; They work best if you use the Block option.<br>]]>
   <pubDate>Wed, 16 Jul 2014 18:12:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27609&amp;title=coppy-follow-up#27609</guid>
   <title><![CDATA[Coppy follow up : Hi,I would like to know if there...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27608&amp;title=coppy-follow-up#27608</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=483918">SamaonA</a><br /><strong>Subject:</strong> 10463<br /><strong>Posted:</strong> 16.Jul.2014 at 16:00<br /><br />Hi,<div><br></div><div>I would like to know if there function<span style="line-height: 1.4;">&nbsp;like array,unction which allow you to follow&nbsp;</span><span style="line-height: 1.4;">up any kind of line, and not only determine by circle or square.</span></div><div><span style="line-height: 1.4;"><br></span></div><div><span style="line-height: 1.4;">Thank you very much,</span></div>]]>
   <pubDate>Wed, 16 Jul 2014 16:00:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10463&amp;PID=27608&amp;title=coppy-follow-up#27608</guid>
