  <title>CAD Forum discussion (EN) : trim</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : trim]]></description>
  <pubDate>Sat, 05 Sep 2026 22:02:20 +0000</pubDate>
  <lastBuildDate>Thu, 28 Aug 2008 08:48:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1056</WebWizForums:feedURL>
   <title><![CDATA[trim : Probably better command will be...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1056&amp;PID=2820&amp;title=trim#2820</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=14249">PepaR</a><br /><strong>Subject:</strong> 1056<br /><strong>Posted:</strong> 28.Aug.2008 at 08:48<br /><br />Probably better command will be WIPEOUT, or in new&nbsp;AutoCAD version, you can select parto of block for trimming other entites. <span style="font-size:10px"><br /><br />Edited by PepaR - 28.Aug.2008 at 08:50</span>]]>
   <pubDate>Thu, 28 Aug 2008 08:48:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1056&amp;PID=2820&amp;title=trim#2820</guid>
   <title><![CDATA[trim : does any know if you can select...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1056&amp;PID=2819&amp;title=trim#2819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=17554">jdub13ks</a><br /><strong>Subject:</strong> 1056<br /><strong>Posted:</strong> 27.Aug.2008 at 22:39<br /><br />does any know if you can select a block and use its boundries to trim out another part if they are overlapping??]]>
   <pubDate>Wed, 27 Aug 2008 22:39:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1056&amp;PID=2819&amp;title=trim#2819</guid>
