  <title>CAD Forum discussion (EN) : blocks</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : blocks]]></description>
  <pubDate>Mon, 26 Oct 2026 02:14:03 +0000</pubDate>
  <lastBuildDate>Wed, 06 Aug 2014 11:41:22 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10596</WebWizForums:feedURL>
   <title><![CDATA[blocks : Take a look at this...http://w...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27846&amp;title=blocks#27846</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10596<br /><strong>Posted:</strong> 06.Aug.2014 at 11:41<br /><br />Take a look at this...<br><br>http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4581<br>]]>
   <pubDate>Wed, 06 Aug 2014 11:41:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27846&amp;title=blocks#27846</guid>
   <title><![CDATA[blocks :  Yes thy work fine at first ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27844&amp;title=blocks#27844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=490984">Nivek73</a><br /><strong>Subject:</strong> 10596<br /><strong>Posted:</strong> 06.Aug.2014 at 00:35<br /><br />Yes thy work fine at first<div></div>]]>
   <pubDate>Wed, 06 Aug 2014 00:35:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27844&amp;title=blocks#27844</guid>
   <title><![CDATA[blocks : Nivek73, are the DDUNITS settings...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27827&amp;title=blocks#27827</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 10596<br /><strong>Posted:</strong> 05.Aug.2014 at 07:23<br /><br />Nivek73, are the DDUNITS settings equal on the 2 files, the one in wich you want to insert the file/block and the one in the block/file inserted ?<DIV>If they are it should mean that the 2 were not drawn at scale 1/1 like John said.</DIV><DIV>If they are not it should mean that :</DIV><DIV>-1- The 2 were not drawn at scale 1/1 or</DIV><DIV>-2- there is at least one file file with NO insertion scale declared</DIV>]]>
   <pubDate>Tue, 05 Aug 2014 07:23:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27827&amp;title=blocks#27827</guid>
   <title><![CDATA[blocks : Were your standard blocks drawn...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27825&amp;title=blocks#27825</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10596<br /><strong>Posted:</strong> 05.Aug.2014 at 00:19<br /><br />Were your standard blocks drawn at full size (1:1 scale)?&nbsp; Yes or No.<br>]]>
   <pubDate>Tue, 05 Aug 2014 00:19:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27825&amp;title=blocks#27825</guid>
   <title><![CDATA[blocks :  Whatever drawing you took them...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27824&amp;title=blocks#27824</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=490995">Karina-gig</a><br /><strong>Subject:</strong> 10596<br /><strong>Posted:</strong> 04.Aug.2014 at 18:42<br /><br />Whatever drawing you took them from probably had a different scale and or parameters and now they do not match the current scale. You would have to change the scale of the blocks in the drawing they were created in to match the current scale to want use.&nbsp;Then bring them over into the new drawing. &nbsp;]]>
   <pubDate>Mon, 04 Aug 2014 18:42:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27824&amp;title=blocks#27824</guid>
   <title><![CDATA[blocks :  My standerd blocks have become...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27823&amp;title=blocks#27823</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=490984">Nivek73</a><br /><strong>Subject:</strong> 10596<br /><strong>Posted:</strong> 04.Aug.2014 at 17:56<br /><br />My standerd blocks have become very small when I insert them]]>
   <pubDate>Mon, 04 Aug 2014 17:56:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10596&amp;PID=27823&amp;title=blocks#27823</guid>
