  <title>CAD Forum discussion (EN) : Help w/ removing images</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Help w/ removing images]]></description>
  <pubDate>Sat, 05 Sep 2026 21:21:30 +0000</pubDate>
  <lastBuildDate>Wed, 29 Oct 2008 17:22:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1073</WebWizForums:feedURL>
   <title><![CDATA[Help w/ removing images : I&amp;#039;m using 2008 LT and have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=3408&amp;title=help-w-removing-images#3408</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23905">sbarson</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 29.Oct.2008 at 17:22<br /><br />I'm using 2008 LT and have also come across this issue. I have had a 'bolt on' (slingshot) added to my LT to bring it up to somewhere near full version although it can leave a lot to be desired. However, this bolt on <U>does</U>&nbsp;allow images to be detached in the same fashion as 2008 full. If you are still having problems I suggest you do a search for this software.<DIV></DIV>If anyone has found another way of detaching images from AutoCAD LT I would love to know as other users in my office have the same issue and don't have the software.]]>
   <pubDate>Wed, 29 Oct 2008 17:22:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=3408&amp;title=help-w-removing-images#3408</guid>
   <title><![CDATA[Help w/ removing images : Maybe it&amp;#039;s because I have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2922&amp;title=help-w-removing-images#2922</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18233">nmilsaps</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 05.Sep.2008 at 18:42<br /><br />Maybe it's because I have LT?&nbsp; Is anyone else using that?]]>
   <pubDate>Fri, 05 Sep 2008 18:42:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2922&amp;title=help-w-removing-images#2922</guid>
   <title><![CDATA[Help w/ removing images : If you click on &amp;#034;unload&amp;#034;,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2921&amp;title=help-w-removing-images#2921</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18233">nmilsaps</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 05.Sep.2008 at 18:40<br /><br />If you click on "unload", it will just remove the image on the dwg BUT it will leave the image frame and the reference.&nbsp; So I erase the actual image in the dwg file.&nbsp; Then it says Unreferenced.&nbsp; I can't purge it anymore than it already is.&nbsp; Here is a screenshot of that.<br><br><img src="http://pickup.cpdhoust&#111;n.com/test2.JPG" border="0" />]]>
   <pubDate>Fri, 05 Sep 2008 18:40:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2921&amp;title=help-w-removing-images#2921</guid>
   <title><![CDATA[Help w/ removing images : OK, OK... Started over with a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2920&amp;title=help-w-removing-images#2920</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18233">nmilsaps</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 05.Sep.2008 at 18:35<br /><br />OK, OK...&nbsp; Started over with a new dwg.&nbsp; purged everything just incase.&nbsp; Inserted my image block, then directed it to locate an image"dog.jpg" on my desktop.&nbsp; Here is a screenshot.&nbsp; Notice there is not a detach button.<br><br><img src="http://pickup.cpdhoust&#111;n.com/test1.JPG" border="0" /><br>]]>
   <pubDate>Fri, 05 Sep 2008 18:35:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2920&amp;title=help-w-removing-images#2920</guid>
   <title><![CDATA[Help w/ removing images :   nmilsaps wrote:Tried that already...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2908&amp;title=help-w-removing-images#2908</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=17594">cganiere</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 04.Sep.2008 at 20:19<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by nmilsaps" alt="Originally posted by nmilsaps" style="vertical-align: text-bottom;" /> <strong>nmilsaps wrote:</strong><br /><br />Tried that already also, the image block is on the xref dwg, the xref_arch dwg, and the main dwg.  Probably because they were made from the same dwg file that originally had the image block secretly attached.  Is my only option to set up a new dwg and copy/paste the xref into it?<br /></td></tr></table> <br /><br />First find which xref the image was originally in. Detach it from that xref, purge, save and reload and it should be gone.<br /><br />I find that often drawings from consultants or title blocks have logos or other images attached, but not found. ]]>
   <pubDate>Thu, 04 Sep 2008 20:19:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2908&amp;title=help-w-removing-images#2908</guid>
   <title><![CDATA[Help w/ removing images : Tried that already also, the image...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2904&amp;title=help-w-removing-images#2904</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18233">nmilsaps</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 04.Sep.2008 at 17:31<br /><br />Tried that already also, the image block is on the xref dwg, the xref_arch dwg, and the main dwg.&nbsp; Probably because they were made from the same dwg file that originally had the image block secretly attached.&nbsp; <br>Is my only option to set up a new dwg and copy/paste the xref into it?<br>]]>
   <pubDate>Thu, 04 Sep 2008 17:31:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2904&amp;title=help-w-removing-images#2904</guid>
   <title><![CDATA[Help w/ removing images : unload it from the xref, not the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2903&amp;title=help-w-removing-images#2903</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18155">jimithing</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 04.Sep.2008 at 16:59<br /><br />unload it from the xref, not the dwg it references, that should take it out]]>
   <pubDate>Thu, 04 Sep 2008 16:59:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2903&amp;title=help-w-removing-images#2903</guid>
   <title><![CDATA[Help w/ removing images :  I know what you are talking...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2887&amp;title=help-w-removing-images#2887</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18233">nmilsaps</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 03.Sep.2008 at 19:03<br /><br />I know what you are talking about, but I just don't see it in my dialog box.&nbsp; Maybe because it's LT... &nbsp; here is what I see.&nbsp; (REMOVED THE IMAGE, BETTER EXAMPLE BELOW)<span style="font-size:10px"><br /><br />Edited by nmilsaps - 05.Sep.2008 at 18:40</span>]]>
   <pubDate>Wed, 03 Sep 2008 19:03:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2887&amp;title=help-w-removing-images#2887</guid>
   <title><![CDATA[Help w/ removing images : Im trying to recreate your problem....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2886&amp;title=help-w-removing-images#2886</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18224">jcastle</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 03.Sep.2008 at 18:54<br /><br />Im trying to recreate your problem.&nbsp; Use detach rather than unload.&nbsp; Also delete any references in block editor if any remain.<br><br>I hope this helps, im out of ideas<img src="https://www.cadforum.cz/forum_en/smileys/smiley5.gif" border="0" align="absmiddle" alt="C&#111;nfused" /><br>]]>
   <pubDate>Wed, 03 Sep 2008 18:54:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2886&amp;title=help-w-removing-images#2886</guid>
   <title><![CDATA[Help w/ removing images : Thanks for the quick reply...That&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2885&amp;title=help-w-removing-images#2885</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18233">nmilsaps</a><br /><strong>Subject:</strong> 1073<br /><strong>Posted:</strong> 03.Sep.2008 at 18:44<br /><br />Thanks for the quick reply...<br>That's where I'm looking.&nbsp; but there isn't anyway to "delete" it.&nbsp; If you right click, you can choose unload or reload.&nbsp; But unload doesn't do anything.&nbsp; I've already deleted the image block in the cad drawing, but it still shows up in that dialog box.<br>I'm trying to clean up a drawing before I send it out of the office, so not to confuse anyone thinking that something is missing.<br>]]>
   <pubDate>Wed, 03 Sep 2008 18:44:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1073&amp;PID=2885&amp;title=help-w-removing-images#2885</guid>
