  <title>CAD Forum discussion (EN) : Creating 3D Objects</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Creating 3D Objects]]></description>
  <pubDate>Sat, 24 Oct 2026 20:44:39 +0000</pubDate>
  <lastBuildDate>Wed, 04 Feb 2015 11:52:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10880</WebWizForums:feedURL>
   <title><![CDATA[Creating 3D Objects : i think i&amp;#039;m not getting what...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28987&amp;title=creating-3d-objects#28987</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=525425">valdrinhoxha</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 04.Feb.2015 at 11:52<br /><br />i think i'm not getting what i need. i guess i have to work for every object separately. Thank you for your help]]>
   <pubDate>Wed, 04 Feb 2015 11:52:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28987&amp;title=creating-3d-objects#28987</guid>
   <title><![CDATA[Creating 3D Objects : Good!!! ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28986&amp;title=creating-3d-objects#28986</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=534019">machine-element</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 04.Feb.2015 at 11:46<br /><br />Good!!!]]>
   <pubDate>Wed, 04 Feb 2015 11:46:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28986&amp;title=creating-3d-objects#28986</guid>
   <title><![CDATA[Creating 3D Objects : I&amp;#039;m not familiar with Civil...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28977&amp;title=creating-3d-objects#28977</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 03.Feb.2015 at 12:03<br /><br />I'm not familiar with Civil 3D.&nbsp; Have you tried asking your question at the AutoDesk Discussion Forums?&nbsp; There is a forum for Civil 3D.<br>]]>
   <pubDate>Tue, 03 Feb 2015 12:03:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28977&amp;title=creating-3d-objects#28977</guid>
   <title><![CDATA[Creating 3D Objects : Yes I am trying to do that work,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28976&amp;title=creating-3d-objects#28976</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=525425">valdrinhoxha</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 03.Feb.2015 at 11:46<br /><br />Yes I am trying to do that work, and I am using AutoCAD Civil 3D. But it seems that most of houses are different from each other. Thank you very much&nbsp;]]>
   <pubDate>Tue, 03 Feb 2015 11:46:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28976&amp;title=creating-3d-objects#28976</guid>
   <title><![CDATA[Creating 3D Objects : It sounds like you are trying...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28975&amp;title=creating-3d-objects#28975</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 03.Feb.2015 at 11:37<br /><br />It sounds like you are trying to create a house and the surrounding land it sits on.&nbsp; And you are using Civil 3D to do this?<br>]]>
   <pubDate>Tue, 03 Feb 2015 11:37:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28975&amp;title=creating-3d-objects#28975</guid>
   <title><![CDATA[Creating 3D Objects : Hmm, yes I have to create ground...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28974&amp;title=creating-3d-objects#28974</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=525425">valdrinhoxha</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 03.Feb.2015 at 09:31<br /><br />Hmm, yes I have to create ground 3D surface. But, on that ground surface I am trying to build (to create) objects in 3D (like Cubical objects). I have, for example, four base points (on ground) of object and also four points of roof. Is there any easy way to create these 'cubic' or do I have to work in every object separately. Thank you for your help. Kind regars.]]>
   <pubDate>Tue, 03 Feb 2015 09:31:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28974&amp;title=creating-3d-objects#28974</guid>
   <title><![CDATA[Creating 3D Objects : Are you trying to create a surface?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28764&amp;title=creating-3d-objects#28764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 26.Dec.2014 at 18:40<br /><br />Are you trying to create a surface?<br>]]>
   <pubDate>Fri, 26 Dec 2014 18:40:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28764&amp;title=creating-3d-objects#28764</guid>
   <title><![CDATA[Creating 3D Objects : Dear Mr/MrsI am a surveyor. I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28763&amp;title=creating-3d-objects#28763</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=525425">valdrinhoxha</a><br /><strong>Subject:</strong> 10880<br /><strong>Posted:</strong> 26.Dec.2014 at 15:57<br /><br /><div>Dear Mr/Mrs</div><div><br></div>I am a surveyor. I had a job to measure about 250 objects in 30Ha zone. I have measured all base pints and height points of every object. I have created two group of points: group one - base points (ground points) and another group is Height points (all points have X, Y, and Z). Is there any way to create - build all objects into 3D using those two group of points?<div><br></div><div>Thank you!</div>]]>
   <pubDate>Fri, 26 Dec 2014 15:57:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10880&amp;PID=28763&amp;title=creating-3d-objects#28763</guid>
