  <title>CAD Forum discussion (EN) : stp to rfa</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Revit : stp to rfa]]></description>
  <pubDate>Sat, 29 Aug 2026 01:50:55 +0000</pubDate>
  <lastBuildDate>Wed, 31 Dec 2014 17:38:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10887</WebWizForums:feedURL>
   <title><![CDATA[stp to rfa : Yes, you can do that. ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28792&amp;title=stp-to-rfa#28792</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10887<br /><strong>Posted:</strong> 31.Dec.2014 at 17:38<br /><br />Yes, you can do that.<br>]]>
   <pubDate>Wed, 31 Dec 2014 17:38:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28792&amp;title=stp-to-rfa#28792</guid>
   <title><![CDATA[stp to rfa :  Thanks for the feedback. But...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28791&amp;title=stp-to-rfa#28791</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=526102">rouxssel</a><br /><strong>Subject:</strong> 10887<br /><strong>Posted:</strong> 31.Dec.2014 at 17:35<br /><br />Thanks for the feedback. But from what I've read, going through autocad to create the .sat with slow revit down. I&nbsp;have access to vanilla cad, but I also have inventor fusion. I should be able to do the same thing in inventor fusion correct? Open the .stp then convert it to .sat?]]>
   <pubDate>Wed, 31 Dec 2014 17:35:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28791&amp;title=stp-to-rfa#28791</guid>
   <title><![CDATA[stp to rfa : I don&amp;#039;t think you can directly...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28790&amp;title=stp-to-rfa#28790</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10887<br /><strong>Posted:</strong> 31.Dec.2014 at 17:09<br /><br />I don't think you can directly convert from one to another.<br><br>Do you have a machine that runs AutoCAD?&nbsp; You could import the .stp into AutoCAD then export it out as a .sat file which can then be imported into Revit.&nbsp; <br><span style="font-size:10px"><br /><br />Edited by John Connor - 31.Dec.2014 at 17:11</span>]]>
   <pubDate>Wed, 31 Dec 2014 17:09:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28790&amp;title=stp-to-rfa#28790</guid>
   <title><![CDATA[stp to rfa :  We have received an stp file...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28789&amp;title=stp-to-rfa#28789</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=526102">rouxssel</a><br /><strong>Subject:</strong> 10887<br /><strong>Posted:</strong> 31.Dec.2014 at 16:21<br /><br />We have received an stp file from a vender. Is there a way to convert this to rfa format so that the modeled equipment can be brought into our current project in revit?]]>
   <pubDate>Wed, 31 Dec 2014 16:21:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10887&amp;PID=28789&amp;title=stp-to-rfa#28789</guid>
