  <title>CAD Forum discussion (EN) : inserting DGN files into DWG</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : inserting DGN files into DWG]]></description>
  <pubDate>Sat, 05 Sep 2026 00:01:11 +0000</pubDate>
  <lastBuildDate>Tue, 10 Feb 2015 14:43:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=10975</WebWizForums:feedURL>
   <title><![CDATA[inserting DGN files into DWG : Yeah but the OP is using AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29041&amp;title=inserting-dgn-files-into-dwg#29041</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10975<br /><strong>Posted:</strong> 10.Feb.2015 at 14:43<br /><br />Yeah but the OP is using AutoCAD 2010 LT.<br>]]>
   <pubDate>Tue, 10 Feb 2015 14:43:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29041&amp;title=inserting-dgn-files-into-dwg#29041</guid>
   <title><![CDATA[inserting DGN files into DWG :  With versions 2015 you can get...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29040&amp;title=inserting-dgn-files-into-dwg#29040</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 10975<br /><strong>Posted:</strong> 10.Feb.2015 at 14:12<br /><br />With versions 2015 you can get rid of these additional linetypes (if they are present in the DGN)&nbsp;using the -PURGE command.]]>
   <pubDate>Tue, 10 Feb 2015 14:12:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29040&amp;title=inserting-dgn-files-into-dwg#29040</guid>
   <title><![CDATA[inserting DGN files into DWG : I&amp;#039;d be careful about this...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29039&amp;title=inserting-dgn-files-into-dwg#29039</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 10975<br /><strong>Posted:</strong> 10.Feb.2015 at 14:06<br /><br />I'd be careful about this as Microstation brings a lot of linetypes (and maybe fonts?) along for the ride that tend to make the file size of a DWG file balloon out of control.<br>]]>
   <pubDate>Tue, 10 Feb 2015 14:06:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29039&amp;title=inserting-dgn-files-into-dwg#29039</guid>
   <title><![CDATA[inserting DGN files into DWG :  What is the exact error message?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29036&amp;title=inserting-dgn-files-into-dwg#29036</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 10975<br /><strong>Posted:</strong> 10.Feb.2015 at 09:25<br /><br />What is the exact error message? Any DGN v7 or v8 file should work. 99% DGN files are v7 or v8.]]>
   <pubDate>Tue, 10 Feb 2015 09:25:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29036&amp;title=inserting-dgn-files-into-dwg#29036</guid>
   <title><![CDATA[inserting DGN files into DWG :  I am getting an error message...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29034&amp;title=inserting-dgn-files-into-dwg#29034</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=145663">cjohnstonau</a><br /><strong>Subject:</strong> 10975<br /><strong>Posted:</strong> 10.Feb.2015 at 05:40<br /><br />I am getting an error message in 2015LT that stage the DGN file needs to be version 7 or 8.<div>How do I get this DGN file into my 2015LT drawing?</div><div>Thank you in advance.</div><div>Cam</div>]]>
   <pubDate>Tue, 10 Feb 2015 05:40:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=10975&amp;PID=29034&amp;title=inserting-dgn-files-into-dwg#29034</guid>
