  <title>CAD Forum discussion (EN) : line 2D wrong UCS</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : line 2D wrong UCS]]></description>
  <pubDate>Fri, 04 Sep 2026 07:46:36 +0000</pubDate>
  <lastBuildDate>Sat, 07 Mar 2015 18:04:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11030</WebWizForums:feedURL>
   <title><![CDATA[line 2D wrong UCS :  In some DWG drawings (usually...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29263&amp;title=line-2d-wrong-ucs#29263</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 07.Mar.2015 at 18:04<br /><br />In some DWG drawings (usually non-Autodesk DWGs), the normal vector of some objects can cause problems. In these cases the utility "Reset210" might help. See:<div><a href="http://www.cadforum.cz/cadforum_en/rotated-ucs-when-stretching-&#111;bjects-with-grip-editing-tip9916" rel="nofollow">http://www.cadforum.cz/cadforum_en/rotated-ucs-when-stretching-objects-with-grip-editing-tip9916</a></div>]]>
   <pubDate>Sat, 07 Mar 2015 18:04:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29263&amp;title=line-2d-wrong-ucs#29263</guid>
   <title><![CDATA[line 2D wrong UCS : Hello sayrithy, FLATTEN is normaly...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29259&amp;title=line-2d-wrong-ucs#29259</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 07.Mar.2015 at 10:27<br /><br />Hello sayrithy, FLATTEN is normaly working with simple item such as lines, arc and circles but maybe it will be hard with dimensions or solids.<div><span style="line-height: 1.4;">I don't have the problem with solids as I leave them in place in 3D.</span></div><div><span style="line-height: 1.4;">If you want to flatten solids then you will have to use FLATSHOT to generate a flatten geometry ( with or without hidden lines ) and this won't destroy your solids but generate a new entity at Z = 0 if you work with UCS world in an plan view.</span></div><div><span style="line-height: 1.4;">An other way would be to open the properties pannel, select some entities and modify the Z elevation, the problem with this is that you will havz to select at one time only lines and not arcs, circles etc, then only arcs, circles and not lines, dimensions etc.</span></div>]]>
   <pubDate>Sat, 07 Mar 2015 10:27:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29259&amp;title=line-2d-wrong-ucs#29259</guid>
   <title><![CDATA[line 2D wrong UCS :  Hi philippe JOSEPH thanks a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29257&amp;title=line-2d-wrong-ucs#29257</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=541353">sayrithy</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 07.Mar.2015 at 04:59<br /><br />&nbsp;<span id="userPro6" ="msgSidePro" title="View Drop Down">Hi philippe JOSEPH thanks a lot that it work on my some file. <br><br>but in this file </span><span id="userPro6" ="msgSidePro" title="View Drop Down">still not working . Is that have other way to make it ? </span><br><span id="userPro6" ="msgSidePro" title="View Drop Down"><img src="http://www.cadforum.cz/forum_en/uploads/541353/ssssssssssf.JPG" height="316" width="307" border="0" /><img src="uploads/541353/dddddddddddddd.JPG" height="593" width="421" border="0" /></span>]]>
   <pubDate>Sat, 07 Mar 2015 04:59:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29257&amp;title=line-2d-wrong-ucs#29257</guid>
   <title><![CDATA[line 2D wrong UCS : Hello again Sayrithy, I suppose...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29251&amp;title=line-2d-wrong-ucs#29251</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 06.Mar.2015 at 07:42<br /><br />Hello again Sayrithy, I suppose that you are working on a file that's not entirely yours, if not you wouldn't have done these "Z lines" on your 2D drawing.<DIV>Use the command FLATTEN on it and take a 3D point of view to see if all is OK.</DIV><DIV>If the file is big it will take some time, be patient or do it in various steps.</DIV>]]>
   <pubDate>Fri, 06 Mar 2015 07:42:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29251&amp;title=line-2d-wrong-ucs#29251</guid>
   <title><![CDATA[line 2D wrong UCS : First thanks everyone, let&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29248&amp;title=line-2d-wrong-ucs#29248</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=541353">sayrithy</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 06.Mar.2015 at 04:22<br /><br />First thanks everyone, let's me explain more about my problem.<br>I have been draw for plan of 2D (Line use) but the Line it in difference level (Z Value Current Elevation).<br>Can you help me to make the line align to Z:0 all or make it flatten line?<br><img src="uploads/541353/sssssssas.JPG" height="301" width="674" border="0" /><img src="uploads/541353/sssaas.JPG" height="516" width="672" border="0" /><br><span style="font-size:10px"><br /><br />Edited by sayrithy - 06.Mar.2015 at 04:25</span>]]>
   <pubDate>Fri, 06 Mar 2015 04:22:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29248&amp;title=line-2d-wrong-ucs#29248</guid>
   <title><![CDATA[line 2D wrong UCS : uploads/175428/2D_LINE_NOT_OK_WITH_UCS.dwg...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29240&amp;title=line-2d-wrong-ucs#29240</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 05.Mar.2015 at 07:43<br /><br /><a href="http://www.cadforum.cz/forum_en/uploads/175428/2D_LINE_NOT_OK_WITH_UCS.dwg" rel="nofollow">uploads/175428/2D_LINE_NOT_OK_WITH_UCS.dwg</a> <div>&nbsp;</div><div>Hello Sayrithy, maybe you are dealing with what is explained in the AutoCAD file here enclosed. </div><div>Please confirm.</div><div>I have the problem but not the solution.</div><div>Maybe someone around the planet can answer.&nbsp;</div><div><br></div><div>If you want to have all the lines of your drawing at Z:0, then use the command FLATTEN.</div><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 05.Mar.2015 at 17:10</span>]]>
   <pubDate>Thu, 05 Mar 2015 07:43:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29240&amp;title=line-2d-wrong-ucs#29240</guid>
   <title><![CDATA[line 2D wrong UCS : Read about the OSNAPZ System Variable....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29236&amp;title=line-2d-wrong-ucs#29236</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 04.Mar.2015 at 17:52<br /><br />Read about the OSNAPZ System Variable.]]>
   <pubDate>Wed, 04 Mar 2015 17:52:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29236&amp;title=line-2d-wrong-ucs#29236</guid>
   <title><![CDATA[line 2D wrong UCS : I&amp;#039;m not sure what you are...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29235&amp;title=line-2d-wrong-ucs#29235</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 04.Mar.2015 at 17:49<br /><br />I'm not sure what you are asking.&nbsp; Can you provide any further information?<br><br>You want to align a 2D line with a 3D line?<br><span style="font-size:10px"><br /><br />Edited by John Connor - 04.Mar.2015 at 17:50</span>]]>
   <pubDate>Wed, 04 Mar 2015 17:49:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29235&amp;title=line-2d-wrong-ucs#29235</guid>
   <title><![CDATA[line 2D wrong UCS : Hi Can you help me how to make...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29234&amp;title=line-2d-wrong-ucs#29234</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=541353">sayrithy</a><br /><strong>Subject:</strong> 11030<br /><strong>Posted:</strong> 04.Mar.2015 at 16:06<br /><br /><font size="3">Hi Can you help me how to make 2D line with 3D line align and order in WCS 2D.? my AutoCAD File I draw in World USC(WCS)<br>but it not in order with 2D ,That line connect wrong UCS in 3D...... <br>How to make it in order to 2D line?</font><br><font size="3"><img src="http://www.cadforum.cz/forum_en/uploads/541353/Capture.JPG" border="0" /></font>]]>
   <pubDate>Wed, 04 Mar 2015 16:06:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11030&amp;PID=29234&amp;title=line-2d-wrong-ucs#29234</guid>
