  <title>CAD Forum discussion (EN) : acad 2000</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : acad 2000]]></description>
  <pubDate>Tue, 20 Oct 2026 04:23:42 +0000</pubDate>
  <lastBuildDate>Tue, 10 Mar 2015 15:07:18 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11032</WebWizForums:feedURL>
   <title><![CDATA[acad 2000 : If the acad.pgp file had been...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29287&amp;title=acad-2000#29287</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 10.Mar.2015 at 15:07<br /><br />If the acad.pgp file had been moved, or the path to it somehow got messed up, one would think that many more commands accessed via aliases would have been affected.&nbsp; The OP could easily test this and report back his findings.<br>]]>
   <pubDate>Tue, 10 Mar 2015 15:07:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29287&amp;title=acad-2000#29287</guid>
   <title><![CDATA[acad 2000 :   Jesbo wrote:.... DI for distance...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29286&amp;title=acad-2000#29286</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 10.Mar.2015 at 14:43<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Jesbo" alt="Originally posted by Jesbo" style="vertical-align: text-bottom;" /> <strong>Jesbo wrote:</strong><br /><br />.... DI for distance in the command line comes back unknown. I checked my acad pgp file no change there. ...</td></tr></table> <DIV>&nbsp;</DIV><DIV>Has your acad.pgp file been <EM>moved</EM> somehow?&nbsp; Or has its <EM>location been removed</EM> from the Support File Search Path list in Options?&nbsp; If the latter, it could explain a whole variety of other things that might not work,&nbsp;since other needed files are likely to be in the same support location.</DIV>]]>
   <pubDate>Tue, 10 Mar 2015 14:43:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29286&amp;title=acad-2000#29286</guid>
   <title><![CDATA[acad 2000 : Maybe it&amp;#039;s off screen too....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29285&amp;title=acad-2000#29285</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 10.Mar.2015 at 14:08<br /><br />Maybe it's off screen too.&nbsp; Easy to determine just by minimizing the main AutoCAD screen.&nbsp; How many users display their toolbars vertically?&nbsp; That's the only way you could hide the Properties palette using toolbars which can be either horizontal or vertical.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 10.Mar.2015 at 14:09</span>]]>
   <pubDate>Tue, 10 Mar 2015 14:08:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29285&amp;title=acad-2000#29285</guid>
   <title><![CDATA[acad 2000 : May be your properties window...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29284&amp;title=acad-2000#29284</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=534333">ktahameed</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 10.Mar.2015 at 14:01<br /><br /><b>May be your properties window Hiding by another tool bars. please Close another tool bars and check it</b>]]>
   <pubDate>Tue, 10 Mar 2015 14:01:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29284&amp;title=acad-2000#29284</guid>
   <title><![CDATA[acad 2000 : I asked four questions and you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29281&amp;title=acad-2000#29281</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 09.Mar.2015 at 23:25<br /><br />I asked four questions and you answer one.&nbsp; If you went to your doctor complaining of an ailment and he asked four questions would you also answer only one?&nbsp; We are trying to diagnose a problem so we need all the information we can get.&nbsp; Understand?<br><br>Without any further information the best I can offer is try doing a REPAIR of the installation which is NOT the same as an uninstall/reinstall.&nbsp; Totally different procedures.&nbsp; Night and day.<br>]]>
   <pubDate>Mon, 09 Mar 2015 23:25:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29281&amp;title=acad-2000#29281</guid>
   <title><![CDATA[acad 2000 :  Other features you ask.... A...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29280&amp;title=acad-2000#29280</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=539215">Jesbo</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 09.Mar.2015 at 22:01<br /><br />Other features you ask.... A few of my two key commands are no longer&nbsp;working. DI for distance in the command line comes back unknown. I checked my acad pgp file no change there. Any Ideas?<div>Thank you,</div><div>J</div>]]>
   <pubDate>Mon, 09 Mar 2015 22:01:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29280&amp;title=acad-2000#29280</guid>
   <title><![CDATA[acad 2000 : What method are you using to activate...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29241&amp;title=acad-2000#29241</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 05.Mar.2015 at 11:11<br /><br />What method are you using to activate it?<br><br>Have you tried shutting AutoCAD down and restarting it?<br><br>Have you tried resetting your Profile?<br><br>Any other features misbehaving?<br>]]>
   <pubDate>Thu, 05 Mar 2015 11:11:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29241&amp;title=acad-2000#29241</guid>
   <title><![CDATA[acad 2000 :  Properties window wont display...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29238&amp;title=acad-2000#29238</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=539215">Jesbo</a><br /><strong>Subject:</strong> 11032<br /><strong>Posted:</strong> 05.Mar.2015 at 03:39<br /><br /><font size="4">Properties window wont display today, any ideas why?</font>]]>
   <pubDate>Thu, 05 Mar 2015 03:39:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11032&amp;PID=29238&amp;title=acad-2000#29238</guid>
