  <title>CAD Forum discussion (EN) : STATE MAPS</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : STATE MAPS]]></description>
  <pubDate>Sat, 05 Sep 2026 03:04:04 +0000</pubDate>
  <lastBuildDate>Wed, 18 Mar 2015 22:05:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11057</WebWizForums:feedURL>
   <title><![CDATA[STATE MAPS : I did all that.  I even contacted...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29369&amp;title=state-maps#29369</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=539913">dianium500</a><br /><strong>Subject:</strong> 11057<br /><strong>Posted:</strong> 18.Mar.2015 at 22:05<br /><br />I did all that.  I even contacted the state's geology department.  They use other software. Even when I pointed out the picture on their website was created in CAD, they still didn't what I was talking about.  At any rate, I accomplished what I needed and do appreciate the help.  I didn't want to burn too much time on this.&nbsp;&nbsp;&nbsp;&nbsp;]]>
   <pubDate>Wed, 18 Mar 2015 22:05:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29369&amp;title=state-maps#29369</guid>
   <title><![CDATA[STATE MAPS : Did you check the State of Florida...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29368&amp;title=state-maps#29368</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11057<br /><strong>Posted:</strong> 18.Mar.2015 at 19:18<br /><br />Did you check the State of Florida Public Works Department or Department of Transportation or the State Environmental Department?&nbsp; There are many resources at the state level that may have what you are looking for.&nbsp; There might even be something available at the USGS website.&nbsp; Seek and ye shall find.<br><br>I was hoping for a bag of gold from you for at least coming up with two suggestions but your reply will have to do.<br>]]>
   <pubDate>Wed, 18 Mar 2015 19:18:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29368&amp;title=state-maps#29368</guid>
   <title><![CDATA[STATE MAPS : This works, thanks.  I searched...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29367&amp;title=state-maps#29367</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=539913">dianium500</a><br /><strong>Subject:</strong> 11057<br /><strong>Posted:</strong> 18.Mar.2015 at 18:38<br /><br />This works, thanks.  I searched for Florida maps, and nothing turned up.&nbsp;&nbsp;&nbsp;I was hoping for something w/ a bit more detail, but this will do. <br /><br />Yes, I can trace with a polyline, but was hoping to avoid doing that.  I can also walk and chew gum at the same time...  ]]>
   <pubDate>Wed, 18 Mar 2015 18:38:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29367&amp;title=state-maps#29367</guid>
   <title><![CDATA[STATE MAPS : Why not grab it from the 50STATES.dwg...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29364&amp;title=state-maps#29364</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11057<br /><strong>Posted:</strong> 18.Mar.2015 at 17:16<br /><br />Why not grab it from the 50STATES.dwg found right here at the CADforum in the CAD Blocks section?&nbsp; Simple.<br><br>Another option would be to click on the link below and download a PDF of the outline of the State of Florida.&nbsp; Bring it into AutoCAD using the IMAGEATTACH command and trace over it with a polyline.&nbsp; You can do that can't you?<br><br>http://www.theus50.com/outlinemaps-state.php<br><span style="font-size:10px"><br /><br />Edited by John Connor - 18.Mar.2015 at 17:22</span>]]>
   <pubDate>Wed, 18 Mar 2015 17:16:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29364&amp;title=state-maps#29364</guid>
   <title><![CDATA[STATE MAPS : I was hoping someone had a drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29362&amp;title=state-maps#29362</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=539913">dianium500</a><br /><strong>Subject:</strong> 11057<br /><strong>Posted:</strong> 18.Mar.2015 at 16:53<br /><br />I was hoping someone had a drawing for the state of Florida. I have been searching everywhere and I can't seem to find one.  ]]>
   <pubDate>Wed, 18 Mar 2015 16:53:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11057&amp;PID=29362&amp;title=state-maps#29362</guid>
