  <title>CAD Forum discussion (EN) : Newbee question: cut body</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Newbee question: cut body]]></description>
  <pubDate>Mon, 26 Oct 2026 20:29:28 +0000</pubDate>
  <lastBuildDate>Wed, 25 Mar 2015 16:25:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11065</WebWizForums:feedURL>
   <title><![CDATA[Newbee question: cut body : Sounds like your cutting plane...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29413&amp;title=newbee-question-cut-body#29413</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 25.Mar.2015 at 16:25<br /><br />Sounds like your cutting plane is not oriented correctly resulting in a partial cut.&nbsp; That's why when you pick on either the cone or the sphere the entire 3D model is highlighted.&nbsp; Look at the first image I posted.&nbsp; See how the magenta colored surface cuts through and beyond the cone and the sphere?&nbsp; Does your cutting surface do the same?&nbsp; Notice too that the cutting surface is also wider than the widest part of the cone/sphere.&nbsp; This usally guarantees a successful slice.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 25.Mar.2015 at 16:27</span>]]>
   <pubDate>Wed, 25 Mar 2015 16:25:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29413&amp;title=newbee-question-cut-body#29413</guid>
   <title><![CDATA[Newbee question: cut body :  Thanks again for your feedback....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29411&amp;title=newbee-question-cut-body#29411</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=546572">hunsnowboarder</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 25.Mar.2015 at 11:17<br /><br />Thanks again for your feedback. I do not understand what am I doing wrong. It cuts the cone but not sphere. However they are united and when I click on the sphere or cone it selects the whole body. :(]]>
   <pubDate>Wed, 25 Mar 2015 11:17:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29411&amp;title=newbee-question-cut-body#29411</guid>
   <title><![CDATA[Newbee question: cut body : I either use the Surface option...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29410&amp;title=newbee-question-cut-body#29410</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 24.Mar.2015 at 22:53<br /><br />I either use the Surface option or the Object option.&nbsp; If you use the Surface option make sure to check that the surface actually passes all the way through the 3D model.<br>]]>
   <pubDate>Tue, 24 Mar 2015 22:53:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29410&amp;title=newbee-question-cut-body#29410</guid>
   <title><![CDATA[Newbee question: cut body : Thank you a lot for your reply....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29409&amp;title=newbee-question-cut-body#29409</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=546572">hunsnowboarder</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 24.Mar.2015 at 20:15<br /><br />Thank you a lot for your reply. However I just cant find out how to slice it. <br>I allways get fail. I have the options planar object, surface, zaxis, view, zx, zy, yx.<br><br>I draw a line extrude it and selected it as planar object but it says: unable to extract the plane of the selected object.<br><br>:(<br>]]>
   <pubDate>Tue, 24 Mar 2015 20:15:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29409&amp;title=newbee-question-cut-body#29409</guid>
   <title><![CDATA[Newbee question: cut body : Maybe a little closer to what...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29405&amp;title=newbee-question-cut-body#29405</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 24.Mar.2015 at 16:58<br /><br /><img src="uploads/165260/SlicedSphere.JPG" height="479" width="456" border="0" /><br><br>Maybe a little closer to what you are expecting?<br>]]>
   <pubDate>Tue, 24 Mar 2015 16:58:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29405&amp;title=newbee-question-cut-body#29405</guid>
   <title><![CDATA[Newbee question: cut body : A quick example to demonstrate...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29404&amp;title=newbee-question-cut-body#29404</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 24.Mar.2015 at 16:18<br /><br /><img src="uploads/165260/SliceItUp.JPG" height="459" width="436" border="0" /><br><br>A quick example to demonstrate the results of the technique.&nbsp; You could also use the SLICE with Object option using just the line.<br><br><br><br><span style="font-size:10px"><br /><br />Edited by John Connor - 24.Mar.2015 at 16:51</span>]]>
   <pubDate>Tue, 24 Mar 2015 16:18:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29404&amp;title=newbee-question-cut-body#29404</guid>
   <title><![CDATA[Newbee question: cut body : I would extrude a line, creating...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29399&amp;title=newbee-question-cut-body#29399</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 24.Mar.2015 at 12:49<br /><br />I would extrude a line, creating a surface, then use that to cut your 3D model via the SLICE command.<br>]]>
   <pubDate>Tue, 24 Mar 2015 12:49:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29399&amp;title=newbee-question-cut-body#29399</guid>
   <title><![CDATA[Newbee question: cut body :  Hello Everyone!This is the first...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29396&amp;title=newbee-question-cut-body#29396</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=546572">hunsnowboarder</a><br /><strong>Subject:</strong> 11065<br /><strong>Posted:</strong> 24.Mar.2015 at 11:30<br /><br />Hello Everyone!<div><br>This is the first time I write to this forum, so please be gentle! <img src="https://www.cadforum.cz/forum_en/smileys/smiley1.gif" height="17" width="17" border="0" alt="Smile" title="Smile" />&nbsp;</div><div>&nbsp;</div><div>I am very new to AutoCad and I would like to learn it bit by bit. <br><br>The problem I have now, is that I would like cut through a body. I do not need the section plane, actually I would like to cut the body and delete the upper part. Is it possible?</div><div>&nbsp;</div><div>What I did so far is that I created a cone and a sphere and I united them. (please see picture below). Next I created a rectangle and moved and rotated at the position where the cut should be made.</div><div>&nbsp;</div><div>Could you please guide me and/or give me hints how could I cut that body (sphere+cone)?</div><div>&nbsp;</div><div>THank you in advance! :)</div><div>&nbsp;</div><div><img src="uploads/546572/probllema_2.jpg" height="494" width="800" border="0" />AD and I would like to </div>]]>
   <pubDate>Tue, 24 Mar 2015 11:30:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11065&amp;PID=29396&amp;title=newbee-question-cut-body#29396</guid>
