  <title>CAD Forum discussion (EN) : Open dialog box issue</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Open dialog box issue]]></description>
  <pubDate>Sat, 05 Sep 2026 05:03:42 +0000</pubDate>
  <lastBuildDate>Wed, 29 Oct 2008 18:39:13 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1117</WebWizForums:feedURL>
   <title><![CDATA[Open dialog box issue : Yes this worked!! Thanks ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3414&amp;title=open-dialog-box-issue#3414</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23812">wilgey</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 29.Oct.2008 at 18:39<br /><br /><P>Yes this worked!!&nbsp; Thanks</P>]]>
   <pubDate>Wed, 29 Oct 2008 18:39:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3414&amp;title=open-dialog-box-issue#3414</guid>
   <title><![CDATA[Open dialog box issue : easy one: type in &amp;#034;filedia&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3409&amp;title=open-dialog-box-issue#3409</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 29.Oct.2008 at 17:59<br /><br />easy one:<br />type in "filedia" and set to "1"<br />if set to "0" the dialog box will not open.<br /><br />Hopefuly it will help next time ...]]>
   <pubDate>Wed, 29 Oct 2008 17:59:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3409&amp;title=open-dialog-box-issue#3409</guid>
   <title><![CDATA[Open dialog box issue : I have the same issue has anyone...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3398&amp;title=open-dialog-box-issue#3398</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23812">wilgey</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 29.Oct.2008 at 00:25<br /><br />I have the same issue has anyone found the how to solve this problem?]]>
   <pubDate>Wed, 29 Oct 2008 00:25:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3398&amp;title=open-dialog-box-issue#3398</guid>
   <title><![CDATA[Open dialog box issue :   jcastle wrote:okay, its fixed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3015&amp;title=open-dialog-box-issue#3015</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 19.Sep.2008 at 15:09<br /><br /><P><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by jcastle" alt="Originally posted by jcastle" style="vertical-align: text-bottom;" /> <strong>jcastle wrote:</strong><br /><br />okay, its fixed for the time being...<BR><BR>I don't know what happened but I was trying to see if the same issue would occur in project manager.&nbsp; I opened a project and the browser worked fine.&nbsp; When i was showing the issue to a co-worker my "open" dialog box is working again.<BR><BR><img src="https://www.cadforum.cz/forum_en/smileys/smiley5.gif" border="0" align="absmiddle" alt="C&#111;nfused" /><BR></td></tr></table> </P><P>Check SDI Mode:</P>]]>
   <pubDate>Fri, 19 Sep 2008 15:09:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3015&amp;title=open-dialog-box-issue#3015</guid>
   <title><![CDATA[Open dialog box issue : Maybe Windows had not enough resources...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3004&amp;title=open-dialog-box-issue#3004</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 17.Sep.2008 at 16:13<br /><br /><P>Maybe Windows had not enough resources (memory) to open another window (dialog).</P>]]>
   <pubDate>Wed, 17 Sep 2008 16:13:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3004&amp;title=open-dialog-box-issue#3004</guid>
   <title><![CDATA[Open dialog box issue : okay, its fixed for the time being...I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3003&amp;title=open-dialog-box-issue#3003</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18224">jcastle</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 17.Sep.2008 at 16:03<br /><br />okay, its fixed for the time being...<br><br>I don't know what happened but I was trying to see if the same issue would occur in project manager.&nbsp; I opened a project and the browser worked fine.&nbsp; When i was showing the issue to a co-worker my "open" dialog box is working again.<br><br><img src="https://www.cadforum.cz/forum_en/smileys/smiley5.gif" border="0" align="absmiddle" alt="C&#111;nfused" /><br>]]>
   <pubDate>Wed, 17 Sep 2008 16:03:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3003&amp;title=open-dialog-box-issue#3003</guid>
   <title><![CDATA[Open dialog box issue : Thank you for the quick response...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3002&amp;title=open-dialog-box-issue#3002</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18224">jcastle</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 17.Sep.2008 at 15:46<br /><br />Thank you for the quick response Vladimir but it does not appear that dialog box is offscreen.<br><br>Its almost like the command line is a dead link while there is a drawing already open.&nbsp; Normally if i have the "open" dialog box active i can alt+tab and see AutoCAD say "select file".&nbsp; In this case, as soon as there is a drawing open I can use any command line to open a file and command line shows at the bottom of the screen but nothing happens.<br><br>After looking more into this I see that the "new" command line does not work as well.&nbsp; Unless once again, all drawings are closed out of AutoCAD.<br><br><br>]]>
   <pubDate>Wed, 17 Sep 2008 15:46:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3002&amp;title=open-dialog-box-issue#3002</guid>
   <title><![CDATA[Open dialog box issue : You may have your dialog &amp;#034;off-screen&amp;#034;....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3001&amp;title=open-dialog-box-issue#3001</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 17.Sep.2008 at 15:19<br /><br />You may have your dialog "off-screen". Try to increase your Windows resolution or press Alt+Shift+space, down-arrow and try to "hunt" your dialog back to screen with the arrow keys.]]>
   <pubDate>Wed, 17 Sep 2008 15:19:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3001&amp;title=open-dialog-box-issue#3001</guid>
   <title><![CDATA[Open dialog box issue : I cannot get my &amp;#034;Open...&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3000&amp;title=open-dialog-box-issue#3000</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18224">jcastle</a><br /><strong>Subject:</strong> 1117<br /><strong>Posted:</strong> 17.Sep.2008 at 15:12<br /><br />I cannot get my "Open..." (ctrl+o) dialog box to show up when i have an drawing already open.&nbsp; The command line shows the function being active but nothing happens.&nbsp; I can get it to show up if i close out of all active drawings.<br><br>I can still use windows explorer to open multiple projects but it is very inconvenient.&nbsp; Normally i would just reset my computer back a week using system restore, but the company network went down last week and i don't want to lose the change in registry files.<br><br>Any help would be grateful.<br>]]>
   <pubDate>Wed, 17 Sep 2008 15:12:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1117&amp;PID=3000&amp;title=open-dialog-box-issue#3000</guid>
