  <title>CAD Forum discussion (EN) : Command to check connections??</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Command to check connections??]]></description>
  <pubDate>Fri, 06 Nov 2026 07:44:38 +0000</pubDate>
  <lastBuildDate>Mon, 29 Jun 2015 17:05:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11233</WebWizForums:feedURL>
   <title><![CDATA[Command to check connections?? : hello all,I use autocad 2015 MEP...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11233&amp;PID=29979&amp;title=command-to-check-connections#29979</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=505107">bsly22</a><br /><strong>Subject:</strong> 11233<br /><strong>Posted:</strong> 29.Jun.2015 at 17:05<br /><br />hello all,<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;I use autocad 2015 MEP and mostly draw HVAC pipe.. Was wondering if there was a command to check all connections or (snaps) of the node of a pipe to the node of a fitting or a weld?? We do as much prefab as possible in the shop and generate spool sheets for everything we make in the shop.. Pretty sure there used to be a command for 2013 that checked to make sure everything that was supposed to be connected was but i didnt know if that was only for design line wich i never use to draw...&nbsp;&nbsp;&nbsp;thanks for the help..]]>
   <pubDate>Mon, 29 Jun 2015 17:05:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11233&amp;PID=29979&amp;title=command-to-check-connections#29979</guid>
