  <title>CAD Forum discussion (EN) : .stl file Problems</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : .stl file Problems]]></description>
  <pubDate>Sat, 07 Nov 2026 00:33:31 +0000</pubDate>
  <lastBuildDate>Wed, 15 Jul 2015 00:29:58 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11263</WebWizForums:feedURL>
   <title><![CDATA[.stl file Problems : Maybe Fusion 360? Not sure. ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11263&amp;PID=30091&amp;title=stl-file-problems#30091</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11263<br /><strong>Posted:</strong> 15.Jul.2015 at 00:29<br /><br />Maybe Fusion 360?&nbsp; Not sure.<br>]]>
   <pubDate>Wed, 15 Jul 2015 00:29:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11263&amp;PID=30091&amp;title=stl-file-problems#30091</guid>
   <title><![CDATA[.stl file Problems : Hi I&amp;#039;m new here and pretty...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11263&amp;PID=30090&amp;title=stl-file-problems#30090</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=572917">kauai1800</a><br /><strong>Subject:</strong> 11263<br /><strong>Posted:</strong> 14.Jul.2015 at 20:49<br /><br />Hi I'm new here and pretty new to CAD. Unfortunately for me I learned to do everything in Sketchup and now I'm having problems as I try to cut parts. I used my 3D printer to mock up the pieces, so this is why I was using .stl files at all.<br><br>When it came time to cut aluminum parts I used PROTO LABS - and they have been able to cut parts from the .stl file so far. However right now I need to convert an .stl file to a .dwg file. because the .stl file is causing strange milling marks. <br><br>I used the convertor found here on the forum and it gave me a .dxf file instead of a .dwg. Why does the .stl to .dwg convertor give a .dxf file instead of a .dwg file?&nbsp; Am I missing something?<br><br>PROTOLABS couldn't quote the part using the .dxf file so I asked them to see if they can try loading the .dxf file into Solidworks and converting it. I'll find out if they were able to do this.<br><br>My question is this - aside from going all the way back to square one and learning a whole new software package like AutoCAD or Solidworks - is there ANY easy way to go from an .stl file to a .dwg file or other widely used file format?<br><br>Sorry to pop in with these newbie questions but I could really use some guidance..<br><br>Thanks!<br>]]>
   <pubDate>Tue, 14 Jul 2015 20:49:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11263&amp;PID=30090&amp;title=stl-file-problems#30090</guid>
