  <title>CAD Forum discussion (EN) : Block in Bilbliothek</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Block in Bilbliothek]]></description>
  <pubDate>Sat, 05 Sep 2026 00:43:20 +0000</pubDate>
  <lastBuildDate>Wed, 15 Jul 2015 18:02:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11267</WebWizForums:feedURL>
   <title><![CDATA[Block in Bilbliothek : Create a block for your library...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11267&amp;PID=30103&amp;title=block-in-bilbliothek#30103</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11267<br /><strong>Posted:</strong> 15.Jul.2015 at 18:02<br /><br />Create a block for your library using the WBLOCK command.&nbsp; Create it on Layer 0 so that when inserted the block will take on the color and the linetype of the layer the block is inserted on.&nbsp; When asked to specify a basepoint use your OSnaps to pick on part of the block geometry.&nbsp; Don't use 0,0 as a basepoint for your block.<br><br>This is all explained in the AutoCAD Help file.<br>]]>
   <pubDate>Wed, 15 Jul 2015 18:02:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11267&amp;PID=30103&amp;title=block-in-bilbliothek#30103</guid>
   <title><![CDATA[Block in Bilbliothek : Hallo,wie kann ich aus einer bestehenden...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11267&amp;PID=30101&amp;title=block-in-bilbliothek#30101</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=571098">Eifelscrofa</a><br /><strong>Subject:</strong> 11267<br /><strong>Posted:</strong> 15.Jul.2015 at 17:44<br /><br />Hallo,<br><br>wie kann ich aus einer bestehenden Zeichnung einen Block erstellen, bzw der Bibliothek zufĂĽhren?<br><br>Danke und GrĂĽĂźe<br>]]>
   <pubDate>Wed, 15 Jul 2015 17:44:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11267&amp;PID=30101&amp;title=block-in-bilbliothek#30101</guid>
