  <title>CAD Forum discussion (EN) : Opening a .bak file</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Opening a .bak file]]></description>
  <pubDate>Tue, 03 Nov 2026 17:03:20 +0000</pubDate>
  <lastBuildDate>Sun, 26 Jul 2015 13:55:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11282</WebWizForums:feedURL>
   <title><![CDATA[Opening a .bak file : You might want to clean the drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11282&amp;PID=30160&amp;title=opening-a-bak-file#30160</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11282<br /><strong>Posted:</strong> 26.Jul.2015 at 13:55<br /><br />You might want to clean the drawing up by using the -purge (Regapps first, then All) and Audit commands.<br>]]>
   <pubDate>Sun, 26 Jul 2015 13:55:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11282&amp;PID=30160&amp;title=opening-a-bak-file#30160</guid>
   <title><![CDATA[Opening a .bak file : Ok, I figured it out on my own....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11282&amp;PID=30146&amp;title=opening-a-bak-file#30146</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=294101">fsurf02</a><br /><strong>Subject:</strong> 11282<br /><strong>Posted:</strong> 22.Jul.2015 at 22:15<br /><br />Ok, I figured it out on my own. &nbsp;Once I converted it I had to go through drawing recovery and open the dwg file. &nbsp;Mission accomplished sorry to waste anyone's time.]]>
   <pubDate>Wed, 22 Jul 2015 22:15:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11282&amp;PID=30146&amp;title=opening-a-bak-file#30146</guid>
   <title><![CDATA[Opening a .bak file : Hello all,I have researched this...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11282&amp;PID=30145&amp;title=opening-a-bak-file#30145</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=294101">fsurf02</a><br /><strong>Subject:</strong> 11282<br /><strong>Posted:</strong> 22.Jul.2015 at 22:01<br /><br />Hello all,<div><br></div><div>I have researched this on here, but am still having issues. &nbsp;Basically, what happened was I closed a file I was in on accident and didn't save and lost a whole days' worth of work. &nbsp;I really, really, really need to recover the file. &nbsp;I have the autosave function backing up my file every 5 minutes or so and it I was able to find the .bak file in my temp folder.</div><div><br></div><div>I copied the .bak file to my desktop and converted the extension to a dwg file (by going to folder options and changing the setting to view file extensions not simply adding .dwg file to the end of a .bak file). &nbsp;I can see the file is now a DWG file and it even is 2,262 KB and I can even see the drawing in preview pane, however, when I click on it, it opens autocad to a blank Drawing1 file. Nothing pops up or anything saying it can't locate the file or anything of that nature.</div><div><br></div><div>Anyone have any ideas? &nbsp;Should I try a reboot? &nbsp;I can't attach either file (the backup or the dwg file I made from the backup) but I can email it possibly if someone wants to try on their end. &nbsp;Thanks!</div>]]>
   <pubDate>Wed, 22 Jul 2015 22:01:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11282&amp;PID=30145&amp;title=opening-a-bak-file#30145</guid>
