  <title>CAD Forum discussion (EN) : Blank Ribbon</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Blank Ribbon]]></description>
  <pubDate>Sat, 05 Sep 2026 06:21:44 +0000</pubDate>
  <lastBuildDate>Fri, 14 Aug 2015 14:37:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=11318</WebWizForums:feedURL>
   <title><![CDATA[Blank Ribbon : Solved thanks you...Tools, Workspaces,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11318&amp;PID=30255&amp;title=blank-ribbon#30255</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=244354">LeeP</a><br /><strong>Subject:</strong> 11318<br /><strong>Posted:</strong> 14.Aug.2015 at 14:37<br /><br />Solved thanks you...<br><br>Tools, Workspaces, AutoCAD Classic.<br><br>Then switched back to Drafting &amp; Annotation.<br><br>Closed &amp; restarted and the ribbon opens as it should.<br><br>Thank you!<br>]]>
   <pubDate>Fri, 14 Aug 2015 14:37:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11318&amp;PID=30255&amp;title=blank-ribbon#30255</guid>
   <title><![CDATA[Blank Ribbon : Some suggestions here.http://k...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11318&amp;PID=30254&amp;title=blank-ribbon#30254</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 11318<br /><strong>Posted:</strong> 14.Aug.2015 at 14:25<br /><br />Some suggestions here.<br><br>http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-The-Ribbon-does-not-have-any-tabs-or-panels-currently-loaded.html<br><span style="font-size:10px"><br /><br />Edited by John Connor - 14.Aug.2015 at 14:26</span>]]>
   <pubDate>Fri, 14 Aug 2015 14:25:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11318&amp;PID=30254&amp;title=blank-ribbon#30254</guid>
   <title><![CDATA[Blank Ribbon : Hi,AutoCAD 2012 stopped unexpectedly...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11318&amp;PID=30253&amp;title=blank-ribbon#30253</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=244354">LeeP</a><br /><strong>Subject:</strong> 11318<br /><strong>Posted:</strong> 14.Aug.2015 at 14:21<br /><br />Hi,<br><br>AutoCAD 2012 stopped unexpectedly this morning and sent a crash report to Autodesk.<br><br>After rebooting the PC and starting AutoCAD again, the ribbon is blank and just has text telling me , "The Ribbon does not have any tabs or panels currently loaded"<br><br>I can get the Menu Bar to show and I can open drawings. But there is nothing in the ribbon. All menu drop downs work and I can use tools via the drop down menus.<br><br>Anyone have any ideas please, or is this going to be a re-install of the software?<br><br>Cheers,<br>Lee<br>]]>
   <pubDate>Fri, 14 Aug 2015 14:21:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=11318&amp;PID=30253&amp;title=blank-ribbon#30253</guid>
